Power Display is Pink
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Borninblue, Mar 24, 2019.
  1. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    So I switched out the old 12v with a fresh new OEM battery couple weeks ago. I’m noticing now the dash display is pink and faded when it goes into the power section of fuel economy screen. The arrows are also pink in the display screen where it shows when it cycles from battery to the engine. Everything else is bright green, not sure what happened that would cause this?
  2. FuelMiser
    FuelMiser Senior Member
    1,300
    887
    Monument, CO
    Post a picture...
    Raytheeagle likes this.
    49,498
    check the 12v voltage
