Power inverter overnight to charge laptop?
Discussion in 'Gen 3 Prius Audio and Electronics' started by Fin, Jul 26, 2020.
  1. Fin
    Fin New Member
    Minnesota, USA
    Hi! Anyone know if I'm able to run a 12V to 110V AC Car inverter
    overnight so I can charge by laptop? Don't want to wake up to a dead battery.
    Thanks!
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Unless you leave the car "ON" (in the ready mode) so that the engine will run when needed, you probably WILL wake up to a dead battery.
    You would be MUCH better off to run the inverter from a second battery or a jump pack.
    Or have a spare battery for the laptop.
    Fin likes this.
  3. ASRDogman
    ASRDogman Senior Member
    7,832
    3,990
    Wouldn't it just be easier to plug it into a 117vac wall socket?
  4. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    It wouldn’t be like PC if things were kept simple and easy.
    ASRDogman likes this.
