power inverter professional installation
Discussion in 'Gen 4 Prius Main Forum' started by Rick Ironton, Jul 14, 2020.
  1. Rick Ironton
    Rick Ironton New Member
    I want a power inverter installed here in Tampa.
    I've checked with Toyota dealerships, auto repair shops, audio shops, auto parts dealers and no one will install an after market inverter.
    Any suggestion as to who will install an inverter?
    52,371
    welcome!
    ask todd at tampa hybrids. maybe he knows someone
    Mambo Dave and jerrymildred like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    +1!
    Home - Tampa Hybrids Inc.
    Todd is terrific!! Before the virus hit, he was getting too busy to deal with all the customers, but I imagine things are slower now. Give him a call. I never knew there was such a thing as an after market inverter. I thought only Toyota made them. But Todd will know what's what.
  4. Leadfoot J. McCoalroller
    8,140
    7,643
    Pennsylvania
    2018 Prius c
    I would expect audio shops & RV service shops to be the correct sub-specialty for an inverter job.
    You are probably thinking of either the traction or air conditioning inverters in your Prius. They exist as a generic item for other purposes.
    I interpreted OP's request as wanting an inverter that produced household AC from the car's 12v electrical system, as that is probably the most common modification involving a generic inverter on a Prius.
    #4 Leadfoot J. McCoalroller, Jul 15, 2020
    jerrymildred, AzusaPrius and Merkey like this.
  5. jerrymildred
    11,517
    14,157
    Tampa, FL
    That's exactly what I was thinking.
    Never crossed my mind that someone would hire this done. But it would explain the "aftermarket" part.
    #5 jerrymildred, Jul 15, 2020
  6. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Do a GOOGLE search for " priuschat: house power from a prius " - there are quite a few answers there.
    jerrymildred and Merkey like this.
  7. Rick Ironton
    I called Todd and he won't do it since it's not original component.
    jerrymildred and bisco like this.
  8. jerrymildred
    11,517
    14,157
    Tampa, FL
    So I guess you're talking about the kind of inverter that you use to power 120V equipment and not the one under your hood that charges the traction battery. There are several helpful threads around here that deal with how to choose & install one. I'm on the verge of ordering one myself.
  9. Rick Ironton
    I've watched several videos on how to install but I'm not that confident as a tech challenged beginner to attempt it plus I'd like additional insight from a professional as to a power inverter functions.
    Let me know if you stumble across an installer source.
    Thanks
    jerrymildred and krmcg like this.
  10. jerrymildred
    11,517
    14,157
    Tampa, FL
    I see that you're only about 30 miles from me. How about I let you know after I get mine installed and you can see what I did. Maybe we can install yours together.
    Edit to add:
    I just ordered this one. Supposed to arrive tomorrow but I won't have time to install and test till next weekend and I'll have to finish fixing our dryer first.
    #10 jerrymildred, Jul 19, 2020
    Rick Ironton, Mambo Dave and krmcg like this.
  11. Rick Ironton
    Thanks, Jerry.
    My number is xxx-xxx-xxxx
    #11 Rick Ironton, Jul 23, 2020
    jerrymildred likes this.
  12. jerrymildred
    11,517
    14,157
    Tampa, FL
    I did a quick test with it today. I just used the clamps to connect it to the battery using the positive and hooking to the negative after the sensor. I put the car in READY, ran an extension cord from the inverter to the kitchen and plugged the refrigerator into the cord. When the refrigerator ran, it pulled 185 watts according to the inverter's display. My meter showed about 1.4 amps. The label on the fridge says it'll pull 3.4A maximum. DC current was 22A at the highest I saw. So, no problem running the fridge and some lights.
    I should have written down the HV battery SOC before I did this, but IIRC, it didn't change in the 10 minutes or so that I played with it.
    Now I need to decide on what to get for a more convenient installation. I like this one (Quick 175 premium Battery Cable Assembly REAL 2 Gauge AWG w lug/terminal/clamp | eBay) that @Krzysiek_KTA found. Then to decide on a convenient & safe way to tie the AC side into my breaker panel.
    #12 jerrymildred, Jul 23, 2020
  13. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    Other places that might do install are RV or stereo shops.
  14. hill
    8,913
    If you're really hardcore, you could do THIS for an inverter.
    PriUPS-getting electricity FROM your hybrid vehicle
    I went this route with our 2004 Prius - long before the plug-in, which would have made things more practical - but have since moved on to other crazy projects
  15. jerrymildred
    11,517
    14,157
    Tampa, FL
    Looks really thorough!!
    Also looks like the web sites I hard coded 15 years ago, but then I'm guessing this is about a 15 year old site. LOL!
  16. jerrymildred
    11,517
    14,157
    Tampa, FL
    I got the parts today for the 120V end of the project. Will want to order the 12V cables & connector when I get the chance, but this will work.
    Sketch of wiring. Hoped for an 8A breaker. Couldn't find one, so I got 15A for the wiring and will have to trust the inverter to protect itself.
    Here's the $55 pile of parts.
    The plan is to make a switched cable (14/3 SO cable for durability) with an inline circuit breaker (the handy-box stack at left). After turning off the main circuit breaker to the house and all the others except the refrigerator and maybe one other that's on the same phase for lights, I can connect the inverter to the car and plug it into an outlet on my workbench next to the car that's on the same phase as the refrigerator. Put the car in READY, turn on the inverter, and flip the switch on the cable assembly.
    When not in use, the cables and inverter can all be labeled, boxed up together, and kept on a shelf. It's as safe and convenient a method as I can think of short of buying and installing a transfer switch which gets more expensive and involved that I'm willing to dive into for something so rarely used around here. In almost six years living here, we've never had an outage that lasted more than about a half hour, including hurricane Irma.
    The one important step left to do, besides putting this stuff together, is find a good way to route the car's exhaust outside in case the ICE needs to run, which is very likely. I'm not keen on cutting holes in the garage door or wall, but leaving it open isn't something I want either. I'll let that puzzle simmer while I work on other stuff. Maybe it's as easy as punching through the screen on the side door and replacing the screen afterwards. :whistle:
    Mambo Dave likes this.
  17. kwyjibo
    kwyjibo Junior Member
    us
    2018 Prius
    Four Touring
    Thank you for sharing. I remember reading similar threads during past hurricane seasons and wonder if these installations are specific to Prius owners or whether it may be more practical to try this setup on less expensive, older vehicles that are out of warranty.
    Thanks in advance.
  18. jerrymildred
    11,517
    14,157
    Tampa, FL
    If by practical, you mean simple, I think it would be the same. If you mean economical, then no, it would be way way less economical with a gasser.
  19. mc510
    mc510 Junior Member
    22
    2019 Prius Prime
    @jerrymildred would you mind to post a picture of your negative connection? I want to be 100% certain that I understand the correct place to attach.
  20. ChapmanF
    18,526
    While Jerry might come back with a photo, the key is that there's a battery state sensor assembly attached to the negative terminal. The "car" side of that, of course, connects to body ground.
    That means you can make your negative connection at absolutely any good convenient solid connection to the body, engine, etc. Find a nice unpainted bolt and there you are.
    The only place you should avoid is right at the battery negative post, because then you would have bypassed the sensor and your load on the battery would not be counted.
    alanclarkeau, jerrymildred and mc510 like this.
