Power loss & low battery during climb
Discussion in 'Gen 2 Prius Main Forum' started by Tone88, Jul 2, 2011.
  1. Tone88
    Tone88 Junior Member
    27
    San Francisco
    I have an 07 Prius with 90Kmi (bought new) which now loses power while climbing sections of mtn passes. Battery meter shows 1 purple bar and cannot go faster than 50mph. No warning lights or fault codes. Never an issue before & intermittently happens around town. 4 dealer visits and extended tests with TMC field techs have allowed them to duplicate the problem at least twice. Interestingly Toyota doesn't know what or how to fix this. TMC is supposed to respond any day now with some type of offer/solution.
    Any thoughts here on what I should consider or precedent on where the mfgr can't fix the problem?
    Thanks!!
  2. MandiRocker
    MandiRocker Junior Member
    45
    WV
    Do you hit green territory before your climb & then notice this?
  3. Tone88
    27
    San Francisco
    it's usually in the blues about 2/3 full. doesn't hit green very often.
  4. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I've experienced this when climbing the steep sections of I-80 on the way to Reno but usually only in the cold of winter but I was never speed limited. I did feel the power loss though.
  5. M8s
    M8s Retired and Lovin' It
    614
    113
    33
    Colorado and Arizona
    I've experienced this with our 2009s with under 20k miles on them. Going from Silverthorne East on I-70 to the Eisenhower Tunnel is an elvation climb from 8,751 feet to 11,158 feet over the course of about 8 miles. Even with a green battery at the bottom, I run out of juice about 3/4 of the way up and can only go about 50 - 55 mph with the ICE screaming. It would probably help if I started out at 55 mph instead of trying to maintain 65 mph and if I didn't use cruise control.
  6. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    What's the condition of your 12v battery? Is it the original? If so, it probably needs to be replaced.
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I'd concur w/the experiences of F8L and M8s. I'm not sure there's anything to be concerned about.
    I've easily "depleted" the HV battery when climbing hills on highway 152 (connects 101 and I-5) between San Jose and the LA area or Vegas. ICE is screaming and there is much less power available, besides the HV battery looking low on the MFD. (Even at 1 bar, state of charge is actually ~40%, see Prius Palm Mileage Simulator). I can't recall if I was "speed limited" at 50 or 55 mph but definitely had no "reserve power" left to increase my speed much or at all.
    As for checking the 12 volt battery condition, I'd recommend checking it via http://priuschat.com/forums/newbie-forum/73400-weird-stuff-happening-mpgs-dropping-test-battery.html after the car has sat overnight.
    Since the OP mentions "around town" and lives in SF, that can easily happen if you let the HV battery run low via lots of stop and go/idling, esp. w/the AC on. I did it today in city traffic (SoC was showing in the 40s, percentage-wise). Some parts of SF are rather hilly.
  8. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Can't speak for this myself. Have a friend that drives an older Prius......takes yearly trips to Colorado.......he tells me that there are some mountains that he just barely makes it over....forget 50 MPH.......he's doing 30 MPH when he finally reaches the summit.
    I'm guessing that this is normal in a Gen II
  9. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i've learned it's all about weight and speed at which you approach. you will hold power and possibly climb in speed if you start out around 70mph... it's like an ultimate high speed steath (only my opinion.. a few others have said something similar)
    if it's only you, you can do this.. if it's you and a car full of stuff or people... you will not make it over at speed... period...
    if your mileage is dropping during normal commute and you see acceleration problems in town (seat of your pants or battery soc) then it might be something that i've been chatting about for a while which... idk.. maybe i'm the only one... ignition coils. i've had one go out on this car and the car basically didn't tell me anything. i had a mechanic check it too. i found out by pulling coil wires. when coil 1 was pulled, the engine didn't notice a difference, therefore it failed. they are not exactly cheap either.
    back to topic...
  10. Tone88
    27
    San Francisco
    Interesting others here have experienced this as Toyota confirmed this is not normal. Also, I've had the car since new (4.5 years now) and it never did it before, could always maintain 70mph over the passes (I-80 to Tahoe/Truckee from SanFran). Issue starts on the climbs about 10mi past Auburn. Although it's now consistent over the passes, I get the same issue about 1 every 10 days around town. Not as big a deal as there's more of an opty to recharge since it's not a consistent climb. TMC has been VERY interested in this case and gone into extensive testing logging over 1000 miles (they always returned it w/ a full tank and provided a free rental loaner) and acknowledged in writing that they've duplicated the problem and that it's not normal. They also noted that they don't have a fix; I'm curious how they're going to settle this as since I go up over the pass every wk over the winter, it becomes more of a notable issue w/ the car as opposed to an intermittent issue around town....
  11. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    For goodness sake, why haven't they just put a fresh battery in and see if that fixes it? Over time, the battery will degrade and not hold as much energy as it did when new. Voltage depression is well documented with NiMH chemistry. It is in some ways analogous to an engine losing compression, and therefore power/efficiency, with wear and tear. Theoretically, it can be fixed via reconditioning. It would also help too to determine if there are sources of inefficiency, such as the 12V battery already mentioned by firepa63, broken down transaxle fluid, sticky brake calipers/shoes, poor A/C performance (compressor running at full output all the time) etc.
  12. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Yes that's what I think as well.
    I think that what's causing the confusion about "what's normal" here is that if a climb is long enough then, regardless of how good/new is the traction battery, then you can run out of juice for electric boost and then the car can feel sluggish. This is why other users can say they've experienced the same thing as "normal" whereas the OP is sure it's abnormal.
    The OP's traction battery has degraded somewhat (maybe a bit, maybe a lot), so certain passes that previously didn't fully drain the battery now do so.
    Maybe Toyota is pretending not to know what's going on so that they don't have to do warranty on the battery?
  13. Tone88
    27
    San Francisco
    My first thoughts as well were that the batts are simply degrading - makes sense as it was never an issue in the past, but TMC tested the batts multiple times and they test strong - there's usually 1 cell (i think 17ish totoal) that often goes out that they swap & it usually trips an error code. They said that with this mileage and age I shouldn't be seeing this issue. They've tested everything under the sun on this car including engine, transaxel, ski rack on off etc...
    There's 2M of these cars on the road and they confirm this is not normal especially if consistent as mine now is over the pass. Regardless of mileage, a 4 year old car (i.e., modern car) should be able to maintain the 65mph speed limit over a mountain pass.
    Remember, this also happens intermittently around town/regular driving, local hwy or city/stop/go & no repeatable pattern I've been able to figure out yet; suddenly drops to 1 purple bar and loss of power, then recharges. - so not just heavy load situation of going over the pass. I think there may be some electrical/CPU quirk telling the batts not to charge; but i think they've done a bunch of sensor tests/cleaning etc..
    I will hopefully have a response from TMC next wk and will update...just thought I'd post here to gain any other insight. It's been a wonderful car and would prefer to have a fix for this issue....
  14. spinkao
    spinkao New Member
    316
    76
    Czech Republic, EU
    How about battery overheating? Do you hear the battery cooling fan in the rear running when this happens? Perhaps the vent beside the rear passenger seat might be blocked? I knew one guy who experienced similar problems and it turned out that that vent was simply blocked by a rear passenger seatbelt over it.
  15. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Yeah, or dog hair in the vent.
  16. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I've never experienced the speed limiting issue when this happens. I'm also not sure why the 12v battery is being implicated as the cause. We are not talking about little mole hills here. These are long steep grades that simply drain the HV battery.
  17. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    If the 12V battery is going out, then there is a lot of power being drawn off the HV battery to run the DC-DC converter to keep it charged. What Tone88 describes makes sense if the car is having to charge the HV battery with the engine at the same time that it is trying to climb the pass.
  18. Tone88
    27
    San Francisco
    Nope, checked that as well. Seems to function normally an no sign of blockage.
    To Toyota's credit, they've put a lot of time into this as I shot video from my iPhone when it first started happening and provided all the video. Their main goal was to recreate the issue with the computers hooked up and they also brought in Field Technical Specialists. I don't think this board will necessarily be the solution of the fix, but I'm more interested in what TMC would offer. They state they have no fix and can't show what failed item needs to be replaced. Do they buy the car back at FMV? Cut me a check & sign a release? Or give me a shinny new one for the inconvenience! :D
    Has any one ever heard of a case of an auto mfgr buying a car back or providing comp for something they couldn't fix?
  19. jdenenberg
    jdenenberg EE Professor
    3,859
    1,858
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Get to Luscious Garage (or Art's Automotive) in SF for a second opinion.
    JeffD
    Miami Hybrid and Rae Vynn like this.
  20. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    This is driver style mostly. If you start going up a steep slope in any vehicle with limited power and you don't floor it to begin with, or let off the pedal for a second only to reapply it hoping that will give you more juice (as my mother and sister usually do) you lose quite a bit of momentum and slow down to the point where you can't reaccelerate only stop yourself from decelerating more.
    I live in the CO Rockies with a GenII and loaded with me + passenger + ski cargo can do all the passes on I-70 at 70mph to 80mph no problem and keep with the flow of traffic. When you start the climb, push the pedal to the floor. Do not for any reason let up on that pedal. If you start at 70, you will end at 70. If you start at 80, you will end at 80. If you start at 65, then slow down slightly to 60 because you don't want to floor it the whole time or just to readjust your foot, then you will end at 60. If you do that a couple times and your speed drops to 50, then you will end at 50. It is not a hard concept. There is plenty of power to keep it going the same speed you started up the worst stretch of high speed interstate in the country. There is not enough power to start from 0 and accelerate to 80 on that same incline.
    Once your battery is gone, you basically just halved your output power. Not only is the engine working to move you forwards, it is working to recharge the battery, and drive all the electrics by itself. (Well sorta kinda, it is never "by itself" but the analogy works)
    The same phenomenon can be seen with my mother driving her 3.5L V6 with 275 horsepower up the same slope. It does have enough power to reaccelerate, but if it accelerated like that on flat ground that old man from Office Space would beat it in a drag race. She drives at the speed limit up to a car that cannot go fast and slows to match their speed, then tries to overtake in the left lane which is a snail race, only to slow down to merge back into the middle lane... If you do this (which pretty much everyone does) in a Prius, you will not make it to the top at speed.
    Dennis Hill and dave77 like this.
