Power Mirrors Not Working - Help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rstark18, Jul 21, 2014.
  1. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    I went to adjust my power mirrors today and it seems that there is no power to either one. I assume the fuse (#2 ECU-ACC) is okay because the other items on that fuse are working (audio, nav, etc).
    The only thing I've had done recently is new tires. I wouldn't think this would have anything to do with it.
    Anyone have any ideas where I should start to troubleshoot this?
  2. JC91006
    16,827
    8,600
    Check the connection going to the remote on the driver's door panel. Make sure the connection is good.
  3. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    Solved.
    I pulled the switch out and reconnected to make sure the connection was secure. That wasn't the problem.
    I then took it apart gave it a good cleaning and re-lubed the contact points and it's working fine.
