power mode in prius gen 2?
Discussion in 'Gen 2 Prius Main Forum' started by daniel boro, Apr 21, 2015.
  1. daniel boro
    daniel boro Junior Member
    israel afula
    i was late.
    so i used power/combat driving (high acceleration, hard braking and high speed curves).
    a 20 min drive was cut to 10.
    until i turned off the car, it acted as if its in a power mod.
    any press on the accelerator turned on the ICE on high rev
    alas my elm327 is of the defective v2.1 and it got disconnected 2 minutes after i turned on the car no data to verify my feeling
    any one can verify or correct me?
    p.s.
    excellent behavior by the car
    of the 4 i had so far this one has the most power and all of then wer 1600cc 1.6l
    #1 daniel boro, Apr 21, 2015
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Wut?
    danboy likes this.
  3. daniel boro
    israel afula
    i did some more Spelling correction.
    if that was the problem maybe now you'll understand it .
    49,437
    probably overheated the batteries, puts it in safe mode, all gas. can you hear the cooling fan?
  5. JC91006
    16,480
    8,397
    well keep on driving it with the built in turbo.....seems like it's faster than mine.
  6. daniel boro
    israel afula
    the car is back to normal
    i have 3 min of data from torque
    no HV reading and no HV temp
    avg speed 60 ( mostly 80 and 0) 60 kph=37mph 80kph=50mph
    Motor MG2 Torque(Nm) peek at 93
    Horsepower (At the wheels)(hp) mostly 10`s and 20`s but a number of 40`
    ICE RPM mostly over 3000
    Ambient air temp(ֲ°C) 33=91.4F
    AC on max no way i can hear the batt fan over that :)
    edit:
    fixed the C to F conversion
    #6 daniel boro, Apr 21, 2015
  7. Tideland Prius
    16,146
    Were you happen to be driving in B yesterday when you were late? That might explain the higher revs.
  8. bisco
    49,437
    i thought body temp was 98.6? but i'm not a doctor, i only play one on pchat.
  9. xliderider
    7,869
    3,116
    Honolulu, HI
    Yes, normal body temperature is 98.6 degrees F or 37 degrees C.
  10. bisco
    49,437
    ah, the c gets me every time.
  11. Mendel Leisk
    38,707
    I still relate to 98.6F, and I'm in the great metric North. I happened to notice a missing person description on the news tonight: height and weight were given in the old, imperial system units. Guess they found when they used metric people stayed lost. :whistle:
  12. Tideland Prius
    16,146
    The height in the driver's licence is in imperial intervals even though the units on the card itself is in metric.
    The Prius' OAT calculation is in Celsius, even in US-spec cars. You'll never see the temperature go up/down by a single °F, it'll jump a few.
