Power Seat Won't go Forward
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dragonrand, Oct 26, 2020.
  1. dragonrand
    dragonrand Junior Member
    74
    22
    Springfield, MO
    I rarely adjust the driver seat on my 2012 Pruis to change distance from the pedals, but recently I tried to adjust it forward, and it moved for just a moment and stopped. It seemed to have no problem going backwards, however.
    Any thoughts? Physical obstruction? Needs lube/grease? Tortion cable of some kind broken? Motor going bad? I've rarely used it.
    Is this gonna be difficult or expensive to fix?
    Thanks, all thoughts appreciated in advance.
  2. ChapmanF
    15,575
    Just point the car due east or west, then keep adjusting the seat backwards for about 19,813 miles (should be about right if you're in Springfield, latitude 37.2°).
    dragonrand, jerrymildred and Ed Beaty like this.
  3. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  4. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    My thought is that the guesses of people hundreds (or thousands) of miles aay are worth about as much as a politician's promise. You need to look for mechanical or electrical malfunctions with your eyes, hands, and a multimeter. Might be a bad switch, a broken wire, a stripped gear, a failed spline, etc. It's a pretty basic device but can fail in several ways.
    davecook89t likes this.
  5. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    I'm guessing the seat is now so far from the pedals that you do not feel safe driving the car. Probably you cannot push the seat forward without touching the controls, but can you move the seat if you get out of the car and push the seat forward while simultaneously pushing the control in the same direction? Does the control motor make any sound when pushing the control in either direction? With the car in IG-ON mode (2 presses on the Power button, without your foot on the brake), do the dash lights dim when operating the power seat controls?
    jerrymildred likes this.
  6. jerrymildred
    11,508
    14,110
    Tampa, FL
    A great first step to determine if it's mechanical or electrical. (y)
  7. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Whatever happened to checking the fuse first?
  8. davecook89t
    1,057
    789
    Four Touring
    He(she) said the seat would go backward but not forward. I think that rules out the fuse.
  9. dragonrand
    74
    22
    Springfield, MO
    I tested more this morning and turns out I was wrong. Moves for a second or two then stops, and is same behavior forward AND back. So it's not a one-way-only issue.
  10. ASRDogman
    ASRDogman Senior Member
    6,088
    3,272
    Bet the brushes are dirty. Since you don't move it, except during a blue moon, the contacts
    corrode on the commutator. You'll have to pull the motor out and clean the commutator.
    Since they are not worn, spraying some contact cleaner on the commutator and spinning the motor
    will clean it up.
    #10 ASRDogman, Oct 27, 2020
  11. ChapmanF
    15,575
    s/commuter/commutator/g
    The commuter is located above the seat. :)
  12. jerrymildred
    11,508
    14,110
    Tampa, FL
    I hate riding around with dirty commuters. :LOL:
