Power switch
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Wilsid, Jul 13, 2017.
  1. Wilsid
    Wilsid Junior Member
    91
    doesn't shut car off. Is it the switch or a relay?
    THANKS
    #1 Wilsid, Jul 13, 2017
  2. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    Any other symptoms? Maybe a corroded 12V battery negative cable? Maybe a bad combo meter?
  3. Wilsid
    91
    Whats a combo meter,
    ? dash lites or off, toyota told me switchs do go bad. ill check bat neg.
  4. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    Disconnect the 12V battery and the car will turn off. When you plug it back in after an hour or so, start the car and it should be back to normal. If you still can't turn off the car, you probably have a bad combo meter which I've heard is expensive. The speedometer should also come back on.
  5. Wilsid
    91
    I hooked 12v battery back up and everything is ok,strange car.
    THANKS
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Combo meter is the dashboard assembly. If that goes dark because it is faulty and failing the car will usually not shut off also. if you push the ready button twice it should shut off.
