Power to the hatch door
Discussion in 'Gen 3 Prius Main Forum' started by bkman, Oct 28, 2017.
  1. bkman
    bkman Junior Member
    Fremont, CA
    I'm in the middle of replacing my audio unit. First thing - disconnected negative terminal. Couple of hours later, when the work is finished, reconnected the terminal. Noticed that back door doesn't have power - hatch open button and the small button which locks the car doesn't work. The power is there - ACC mode fine, new audio unit works fine.
    Noticed the kind of switch which is mounted on top of the 12V battery - what is responsible for?
  2. bkman
    bkman Junior Member
    Fremont, CA
    Turns out is was a 12V battery sensor (that switch). I've pressed open button on the remote twice and it enabled the rear door's open button. Problem solved. :)
