Power Window Issues.
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by LordsII, May 5, 2013.
  1. LordsII
    LordsII New Member
    16
    I installed car speakers so I opened all door panels. Speakers were installed perfectly. I put door panels back. However, when I tried rolling windows, driver's and right rear windows could not be rolled down and up (well, they are actually all the way up) but the other two worked fine. How do I set these windows back to normal which I can roll up/down?
  2. LordsII
    LordsII New Member
    16
    Forgot to say I have Prius C One model which only driver's window can be rolled down with one push.
  3. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    try rolling down the front right window with the switch that's on that door.. then roll it up and hold the switch there for a few seconds.
  4. LordsII
    LordsII New Member
    16
    You meant the front left window (driver's side)? Front right window is fine.
  5. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    yeah, that process will reset and reprogram the switches.
    Try it and report back.
  6. SquallLHeart
    826
    247
    San Jose, CA
    oh.. the right rear.. and/or whatever windows that aren't being controlled by the driver switches..
  7. LordsII
    LordsII New Member
    16
    For the windows that arent working, they can't roll down in order to reset.
  8. SquallLHeart
    826
    247
    San Jose, CA
    even from their respective switches on their doors?
  9. LordsII
    LordsII New Member
    16
  10. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    time to pull the door panel back off and make sure you didn't knock a wire loose from the motors.
    RocMills likes this.
