power window problems
Discussion in 'Gen 2 Prius Audio and Electronics' started by aradia7572, Oct 6, 2017.
  1. aradia7572
    aradia7572 Junior Member
    sc
    I have a 2006 Toyota prius. after my boyfriend unhooked an extra amp we had, all the power windows stopped working but the drivers window. No sound comes from the windows when I press any switches. Its not the window lock button, not the power window master switch (ordered one from switchdoctor and it won't even operate the driver window that was working) we checked all the fuses that we could find that operates the power windows but they were fine. What could it be if its not the switch or fuses? Could all 3 window motors but the driver side have bad motors at the same time?
    49,504
    welcome!
    try disconnecting the 12v negative for a few minutes.
    aradia7572 likes this.
  3. aradia7572
    sc
    49,504
    i guess i would start checking inside the drivers door handle. are you competent with a multi meter? seems likely to be the problem area, since the other 3 windows are controlled from there.
  5. aradia7572
    sc
    Yes I can use a multimeter, where would I start? I know absolutely nothing about power windows.Thanks for your response!
  6. bisco
    49,504
    nor do i, but i would start by opening up the drivers door switches and looking for power and continuity through the other 3 windows.
    still, i have no idea how disconnecting an amp could affect anything.
  7. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    got to be a fuse or a loose connector.
  8. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    1) Did you check the power window fuses with a multimeter using continuity test? If NO, then do so.
    2) Highly unlikley the switch and all three motors went bad simultaneously.
    3) Trace the power connection of the disconnected amp wires back to their source. One of these is likley the culprit, causing a short.
