Power wire through firewall for amp install
Discussion in 'Prime Audio, Electronics, and Infotainment' started by G23, Jun 26, 2018.
  1. G23
    G23 Junior Member
    28
    Trying to figure out the best way to run power wire through the firewall to install an amp. Probably 8 gauge wire but possibly 4 gauge. Read in the 4th gen forum that there is giant grommet that can be used. I was assuming the chassis of the 4th gen and prime was the same. Maybe not? Anyways, I've attached a photo of what I believe to be the grommet. If that is the grommet, how would you get the wire through? concerned about poking through there and damaging something underneath. Also, anyone have a photo of an install that shows the wire route through the engine compartment to the battery terminal? Thanks for any info.
  2. 2015BlizzardPriusFour
    2015BlizzardPriusFour Active Member
    171
    142
    Central Valley CA
  3. Heiyu92
    Heiyu92 New Member
    Seal Beach
    Yes you can run the power wire thru that. Just pop it off and run the wire thru. If you shine a light you should see it come thru the firewall
  4. Depe
    Depe Junior Member
    33
    23
    Tennessee
    Four Touring
    I drilled a small how to run the wire through. Then I sealed it with a small grommet and rtv. I initially tried to use that grommet but it was giving me issues and i didnt want water to potentially leak onto the cabin harness.
  5. G23
    G23 Junior Member
    28
    @ Depe. Where on the firewall did you drill the hole? Drilled from the inside I assume? What type of issues were you having with the grommet?
    @Heiyu92. What do you do after you run the wire through, you wouldn't be able to pop in back on with a 4 gauge wire running through it. Cut a hole in the grommet, where the nub is maybe?
  6. muleman
    muleman Junior Member
    56
    49
    rochester ny
    Do you have a pic of where you drilled the fire wall?
