Powering off without Park
Discussion in 'Gen 3 Prius Technical Discussion' started by rpickoff, Apr 24, 2011.
  1. rpickoff
    rpickoff Bob P
    29
    Ticonderoga, NY
    Is it very bad to Power off before putting the car into Park? It seems to go into Park upon hitting the Power button automatically.
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    No problem. I've been doing it since I took delivery in June 2009, as have many other here.
  3. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    ^ Stream is right. It does no harm.
  4. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
  5. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    I do it every time.
  6. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    The advantage to putting it in park before you press power-off is that, when you press the power button, but don't hold it long enough, the car won't power off and you have a danger of rolling forward (or backward if you're in reverse)
  7. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    I read once that someone powered off without putting the car in park and the engine fell completely out of the car and laid there on the driveway just sputtering while the hybrid battery provided the electricity to keep it running and the gas tank was still in the car chassis but the hoses were still running to the car and then the Prius sprang forward with unintended acceleration and literally dragged the engine behind the car but still powering the wheels because the transmission was still engaged which is when the brakes failed as they tend to when you drive over rough pavement and then the car slammed into the front of a store and the whole thing was caught on a security camera.
    2 people like this.
  8. Rocco42
    Rocco42 Member
    115
    30
    Rosendale, NY
    And I have a bridge for sale. :D
  9. ETC(SS)
    6,954
    If you (successfully) power down the car, it will go into park.
    Period.
    I almost always just hit the power button....unless I want to finish out an NPR or talk radio segment before getting out of the car(*). For me, it's just easier that way.
    YMMV.
    (*) Hey Toyota! How about adding the radio to the retained power feature?
  10. TonyPSchaefer
    14,816
    2,499
    66
    Of course that whole diatribe I wrote previously was absolute nonsense. Powering down without first putting the car into Park will, in no way, harm the vehicle. Period.
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    I once powered off without first going into park. My head exploded and flames shot out of my neck.
    What? Well, I got better.
    Seriously, when you power off, the computer presses park for you. There is no difference, other than the ritual.
    Tom
  12. billinmd
    billinmd Member
    184
    28
    Bel Air, MD
    2020 Prius Prime
    For the Gen III, it is on page 163 of the owner's manual. Pressing the power button to turn off the hybrid system will put the car in "park" automatically.
  13. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Why do we have this thread topic every few months?
  14. ETC(SS)
    6,954
    Awwww MAN! :(
    I was juuuust waiting......
    Lotsa people out there buying new Priuses.....
  15. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    If you do it properly (by applying the parking brake) that won't happen.
  16. TonyPSchaefer
    14,816
    2,499
    66
    It turned me into a newt!
  17. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    It turned you into a newt?
  18. stream
    2,977
    452
    Long Island, NY
    This topic--and many others! ;)
    If only there was a way to...search...the forum: :D
    Posting And You... | Flash Videos
  19. ETC(SS)
    6,954
    Ni!!!!
    Or...if you prefer....ekki-ekki-ekki-pitang-zoom-boing! :D
  20. mesojdm
    mesojdm New Member
    23
    nor-cal
    My pri rocks back and forth after putting it in park...?
