Powertrain Fault codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KBK, Mar 24, 2018.
  1. KBK
    KBK Junior Member
    While trying to extricate our 2008 Prius from a snow bank with the left front corner buried,. the Triangle light appeared. The faults that show up are P0606, P1118, P1150 with pending fault P0138 pending. I don't know where to start.
    49,706
    welcome! what did you use to read the codes? are you planning on diy?
  3. Elektroingenieur
    2,515
    3,264
    Three Touring
    Since the car was operated under unusual conditions, if you haven’t noticed any other symptoms, it might be reasonable to write down and then clear the stored diagnostic trouble codes (DTCs) and see which of them (if any) returns after a few more typical drive cycles.
    The car’s software is programmed to store DTCs when it recognizes certain conditions that are not likely to occur in normal driving, but it’s possible that whatever you did to free the car from the snowbank caused some of the same conditions, even though there is nothing actually wrong with the car.
    If any DTCs do return, I’d suggest starting with Toyota’s Repair Manual, available by subscription to techinfo.toyota.com, and perhaps through your local public library, if they sponsor access to the ChiltonLibrary service for their patrons. The Repair Manual has general information (“How To Troubleshoot ECU Controlled Systems”) and a step-by-step procedure for each DTC.
    Keep in mind that the one-line “fortune cookie” (@ChapmanF's apt term) descriptions of the DTCs can be misleading; the Repair Manual explains the conditions that cause the DTC to be stored or pending, which may or may not indicate that the trouble is the part or problem in the description:
    P0606: ECM [Engine Control Module]/PCM [Powertrain Control Module] Processor
    P1118: Coolant Temperature Sensor Circuit For Coolant Heat Storage System
    P1150: Coolant Path Clog of Coolant Heat Storage System
    P0138: Oxygen Sensor Circuit High Voltage (Bank 1 Sensor 2)
    For example, P1150 says “Coolant Path Clog,” but it really means the reading from a temperature sensor didn’t change the way the software was programmed to expect. Under normal conditions, this may indicate a clog, a stuck valve, a problem with the temperature sensor, or a faulty engine control module.
    #3 Elektroingenieur, Mar 24, 2018
    KBK likes this.
  4. KBK
    KBK Junior Member
    I used a PLC KiWI 2 blue tooth reader with Torque software.
    I have reset the fault codes and I'll take it for ride tomorrow to make sure they do not return
    Thanks for the help
    Raytheeagle likes this.
  5. Patrick Wong
    18,200
    6,479
    It is possible that you may have damaged the engine coolant heat recovery system pump and/or canister which are located in front of the left front tire, hiding in the wheel well (must remove fender liner for access), and the oxygen sensor downstream of the catalytic converter. So if the last three DTC reappear, check for physical damage in those areas.
    m.wynn likes this.
  6. KBK
    KBK Junior Member
    OK, so we've driven the car for 100 miles and today the Triangle appeared with the vsc and brake light.
    I connected the reader and there were no codes to be found. I cleared the faults, and the lights came on checked codes and there were none again. I'm having fun!
  7. Patrick Wong
    18,200
    6,479
    Your car has logged DTC. The issue is that the reader you are using is not able to retrieve them.
    m.wynn likes this.
  8. razach969
    razach969 New Member
    Pakistan
  9. razach969
    Pakistan
    Cleaned the catalytic converter of 2008 Prius but milege of petrol is reduced nw :( i don't know why
    #9 razach969, Aug 23, 2018
  10. Patrick Wong
    18,200
    6,479
    Replace the engine ECU (aka ECM). DTC P0606 means that the ECU has detected internal errors. The ECU contains two processors; they perform mutual monitoring and will log a fault code if the processors produce different outputs.
    In this specific case, that fault code means that the two processors either are recommending substantially different throttle positions; or else that they detect substantially different accelerator pedal positions.
    Toyota Techstream will enable you to look at freeze frame info to see the conditions under which the DTC was set. You will also need that to enter the vehicle identification number into the replacement engine ECU. DTC P0630 will be logged if the incorrect VIN is present.
    #10 Patrick Wong, Aug 24, 2018
