Practical Short Term / Long Term Hints?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MrPete, Apr 24, 2022.
  1. MrPete
    MrPete Active Member
    477
    187
    Colorado, USA
    So I have a very pragmatic situation: my sweetie is going on a girls' four day road trip this Thu (3 1/2 days from now) and clearly wants to drive the Prius, as long as it will be safe.
    What makes me a bit nervous: at 200k miles it's acting up a little in some familiar-sounding ways...
    • Over the winter we've had a few of the rough-start events. Turn off, turn on and all is well. Except once for my wife she said it took three tries.
    • One time only, I saw a cylinder 2 misfire code.
    • Definitely losing oil since 110k miles. We check on every fillup.
    I have NOT yet had opportunity to do the EGR cleanup.
    Just now I marked the coolant. It's below half in the container.
    One more tidbit: this video of a 10k mile / two year test of a HG "quick fix" is pretty amazing... and he uses a simple low cost (BT-500) tool to check for HG blow by.
    I don't have a lot of time or money. I'd love input / feedback...
    * Worth doing the BT500 test?
    * Ripping in to do leak-down test looks like it may take... several hours? Worth it to at least know if safe to drive a thousand miles?
    * As long as I do the leak-down, also do EGR/Cooler cleaning? Does that add a few more hours?
    OR... just don't worry about it for this trip, and get to it all pretty soon?
    Thoughts?
    THANKS!
    51,154
    does anyone else have a car?
  3. MrPete
    477
    187
    Colorado, USA
    Not really. She can use our Subie if necessary. Twice the gas cost ;)
  4. Paul E. Highway
    Paul E. Highway Active Member
    206
    129
    Hawaii
    My $0.02:
    -have her take the Subie. Check tire pressures, fluids, drive belts, air filter, battery before they leave.
    -Prius might need head gasket and rings. You can diagnose while the girls trip is on.
    -No head gasket in a bottle.
    Cheers!
    jerrymildred likes this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    This is what I'd do.
  6. rjparker
    rjparker Tu Humilde Sirviente
    9,596
    5,893
    Texas Hill Country
    You have a head gasket problem. 99%. Your sweety will be pretty sour when it strands her 100 miles from home. Rental cars are well over $100 a day and the wait for a tow truck will make her dial up the divorce lawyer. Your best bet is to have a rebuilt replacement engine installed. Not yours. New pistons, rings, machined head, decarboned, new gasket set.
  7. bisco
    51,154
    high gas prices
    road trips
    trying to save money
    pick two
  8. JC91006
    16,673
    8,518
    If paying twice for gas is the issue, imagine a breakdown on the road, it'll 10x the cost of gas and it'll ruin a good road trip!
  9. MrPete
    477
    187
    Colorado, USA
    Sounds like y'all are pretty sure it's way beyond the cold-start vibration that's been endlessly discussed....
    My other question is based on the linked video. Careful use of the correct HG sealant produced a working solution for over a year with no damage. I'm not at all sure this vehicle is worth the cost of "real" HG replacement let alone replacing the block or whatever is "really" needed...
    I know we in PriusChat prefer to Do The Job Right (almost no matter what the cost)... but sometimes it just isn't worth it.
    Has anyone collected experiences with "Head Seal Blown Gasket Repair" (the one on the right in the photo)?
  10. JC91006
    16,673
    8,518
    Well as cars age, parts will need to be replaced to keep them running. These hybrids when they age, need batteries as well, at around $2000 for DIY solutions.
    So on top of the failing HG, you'll need to budget in money for the HV battery and the Brake Actuator/Accumulator failures. They won't be far behind and will cost upwards of $2000 in repairs each.
    On top of that you'll still have the usual suspects that fail over time, like suspension/rusting/electronics/paint issues.
    So my thought are always to get out early or don't get out at all once the money starts to get invested
  11. MrPete
    477
    187
    Colorado, USA
    Already took care of the HV battery ;)
    The failure that truly bugged me: almost $1k to replace the wire harness inside the steering wheel.
  12. bisco
    51,154
    wow, that's awful. i'm only a year behind you :eek:
