Pre-collision Braking
Discussion in 'Prime Main Forum (2017-2022)' started by ukr2, Feb 6, 2017.
  1. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Who has experienced the Pre-collision Braking System?
    I assume in avoiding an accident.
    thatoneraccoon likes this.
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    Anytime you use the cruise-control, it is watching vehicles or objects in front of you. When vehicles slow down or pull out in front of you the vehicle automatically brakes to maintain distance.
  3. ttait
    ttait Active Member
    273
    163
    Southern California
    While driving through Los Angeles towards the grapevine in stop and go traffic in the pouring rain, I experiences the braking system.
    One the one hand, it worked. On the other, I found that it applied the brakes earlier than I wanted at very slow speeds. If the car in front of me stopped, and I was still moving to close the distance, the automatic system essentially jammed on the brakes. I found it abrupt and somewhat disconcerting.
    I found that the only way to keep from getting jerked around was to keep my foot on the brake pedal, because it won't activate while you're braking.
  4. Wattup
    Wattup Junior Member
    Good to hear tpps working. Should save people tons of money by avoiding a collision. Ive only gotten the display to come on telling me to stop. Ive tried to test it but either im too chicken or it needs to be super close for it to engage the brakes ^^
  5. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    I am planning to buy some balloons and tape them to the ground. That way I can test out the precollision system. It's been raining nonstop these days. Didn't have the chance.
  6. ForestBeekeeper
    780
    310
    Maine
    It is monitoring the distance between vehicles, keeping the minimum legal distance. You and I [and most everyone] are accustomed to tail-gating. The proper amount of distance would allow other vehicles to slide into that open space.
  7. MNdriver
    MNdriver Senior Member
    549
    577
    Only if you're using cruise control?
  8. ForestBeekeeper
    780
    310
    Maine
    As far as I know.
  9. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    It would be pretty annoying if it braked while not in cruise control.:D
  10. Wattup
    Im not fully sure if this video is talking about the features of TPPS in our Prius but it seems you don't have to be in cruise control to activate the emergency braking.
    EDIT: Pedestrian detection is included on all Prime models.
    #10 Wattup, Feb 7, 2017
  11. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    It would be even more annoying if it didn't.
    It's designed to prevent accidents, whether you're in cruise control or not.
  12. priuscatprimeguy
    2,730
    2,640
    I disengage my cruise control when I come to a red light to avoid the annoying braking of DRCC. So no, I disagree that it's more annoying
  13. Lee Jay
    5,850
    4,036
    If it only works in cruise control, there's no point in it existing.
  14. bowang
    bowang Member
    45
    37
    Please let us know if it work. And be careful not too fast to avoid deploying air bag.
  15. priuscatprimeguy
    2,730
    2,640
    you did notice I said DRCC? Not pre-collision braking system?
  16. Lee Jay
    5,850
    4,036
    The topic of this thread is the pre-collision braking system, and the people discussing it to which you responded were also discussing that system. Someone thought it was only doing it while DRCC was on, but that isn't the case.
    priuscatprimeguy likes this.
  17. Tideland Prius
    16,623
    Nope. Hope to never have to use PCS Braking. Someone did do a Gen 3 test but that video has been taken down since. The Gen 3 isn't as sophisticated as the Gen 4's but there's plenty of video around from the media event testing the system.
  18. crewdog
    crewdog Acting Ensign Prius Prime
    493
    388
    Woodstock, GA
    While using the DRCC, and a vehicle in front slows down, the car will decrease power or brake to maintain a 1, 2, or 3 bar distance. Don't know about emergency situation though.
    While operating one day normally, without DRCC, in "urban rush hour combat" I had a car cut in front and brake suddenly, and got a big red warning sign "Apply Brakes Now!" or some such, and a loud beep on the display at the same time I applied full stomp on the brake pedal. I can't say for sure if the vehicle braked or not, but I can definitely speak for the warning.
    In normal traffic it seems that approaching another vehicle from behind with the brakes already applied does not trigger the warning; maybe the computer senses the vehicle deceleration.
  19. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Hard braking shouldn't trigger the air bags. It requires the type of near-instantaneous deceleration that occurs most commonly by colliding with a massive object. Which the system then compares with data collected from test crashes. So I doubt there is much risk from making a full-speed run at some balloons.
  20. RJ Primw
    RJ Primw Member
    65
    87
    South Jersey
    Pedestrian detection is only on the Advanced.
