pre-owned vehicle service history - concern
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by buster71, Aug 7, 2013.
  1. buster71
    buster71 Junior Member
    40
    Queens, NY
    How concerned would you be if you saw the following listing in a 2010 prius's vehicle service history? Car presently has approx 19000 miles, and this service was done at approx 10k miles
    ___________________
    CUSTOMER REQUESTS ENGINE DIAGNOS IS CHECK ENGINE LIGHT AND CHECK HYBRID SYSTEM. ~|~P0C73-COOLANT PUMP PERFORMANC E.FOUND NO COOLANT IN INVERTOR R ESERVIOR,FOUND INVERTOR RADITOR LEAKING ~|~R&R INVERTOR RADATIOR
    PARTSNAMEPART #QTYRADIATOR ASSYTOG9010470311SUPER LONG LIFE CTO00272SLLC22
  2. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    Good catch. Find another car.
  3. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
  4. Mike500
    Mike500 Senior Member
    2,593
    764
    Run; just don't walk away!
  5. buster71
    40
    Queens, NY
    Too late. The car is already mine. I found this afterwards when I registered in the Toyota owners website.
    Well, car has seen about 1200 miles since purchased 3 1/2 weeks ago, and everything has been fine so far. Hopefully the car was repaired correctly and won't give me problems. It is the chance you take when buying pre-owned.
  6. macman408
    macman408 Electron Guidance Counselor
    1,179
    366
    Oh well. Hopefully, Toyota's systems are all well-designed to put up those errors and go into limp mode well before any long-term damage is done.
    And even if there is any long term damage, it can often be pretty insignificant. I once worked somewhere and we told manufacturing to build the electronics but not turn them on, because the cooling system was not yet finalized (or sufficient). Well, they apparently missed that direction, so I ended up spending some time figuring out exactly how much the electronics overheated by, and passed that information along to our reliability engineer. He crunched some numbers, and estimated that it only took like 2 weeks out of the total lifetime of the electronics - which, considering we expected it to probably last for 5-10 years, is basically nothing. Your car is designed to last even longer than that, and actually has some thermal protection systems built-in. :)
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The rule of thumb is for every 10C rise in Tj the relative life of the semiconductor is cut in half. The inverter normally operates around 88C when it is happy and working under normal conditions. The Prius will throw a code and say the car is doomed when the temperature rises above 111C. If the car was perfectly fine and then bam all the coolant leaked out and the temp rose to 111C for an hour (not probable, but just an example) then instead of taking 1 hour of life off of the inverter you took 4.6hours off of the life of the inverter in that 1 hour of real time. In a car that will run for decades, this is nothing. If this was something that the owner knew about and taped over the warning light to not be bothered and drove on it for a year, that could be a serious consequence of 4 and a half years cut off the life of the car. Doubtful that happened in the 10K miles before they brought it in.
  8. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    It said the reservoir was empty. Not that the system was empty :eek:
    Considering it has an 8 yr 100K warranty, it's not really something to worry about at this point.
    Just make sure and trade it back to the dealer before the warranty expires :ROFLMAO:
  9. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Probably no big deal if the car was not driven with no coolant at all for a long distance. even less of a worry if it was cool weather conditions at the time. With 19,000 miles you should still have warranty?
  10. buster71
    40
    Queens, NY
    3 year 36,000 basic warranty is expired, but I still have the remainder of the 5 yr/60,000 powertrain and the 10 yr. 150,000 on the hybrid system.
    Anyway, there is nothing I can do about it now so I will just enjoy the car and take things as they go. A further problem may never pop up.
  11. Feri
    Feri Active Member
    761
    144
    That's best.Just enjoy it.
  12. Nora
    Nora Member
    128
    44
    CO
    I'd be very concerned about the technician's spelling. ;)
  13. Feri
    Feri Active Member
    761
    144
    Well spotted!:)
