Precautions before replacing battery?
Discussion in 'Gen 3 Prius Main Forum' started by PriusKyle, Jul 16, 2023.
  1. PriusKyle
    PriusKyle Junior Member
    68
    Virginia
    Hey all,
    Getting close to replacing my 12v aux battery on my 2011 Prius; seen YouTube videos on how to do this but didn’t see any of discussion as to any safety precautions to take before swapping etc.
    I’ve swapped out a battery on a Honda accord gas powered but never a hybrid where 12v is directly connected to.a hybrid battery.
    Any advice or precautions I need to take before I attempt to start loosening the cables on the battery terminals etc.? Better safe than sorry.
    Thx.
  2. JC91006
    16,673
    8,518
    replacing the 12v is very straight forward, not connected to the HV battery
  3. PriusKyle
    68
    Virginia
    So, nothing else to do except to make sure car is off before replacing battery?
  4. JC91006
    16,673
    8,518
    yes nothing to do, just don't cross/mixup the positive and negative wires
    PriusKyle likes this.
  5. bisco
    51,154
    if you want to save some memory settings, put a 12v source on the front jump point.
    pay attention to the vent tube routing
    be careful not to let your tools touch the neg or body when disconnecting the positive and reconnecting
    don't drop the 10mm hold down nut, it's hard to retrieve
  6. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    The precautions you should follow are the same as for changing the 12-volt in any other car.
    Bisco is correct regarding retaining volatile electronic memories.
  7. Mendel Leisk
    40,584
    Disconnect neg cable first, then pos. With new battery connect pos first, then neg. Deal with each connection one at a time.
    Be real careful not to create a short circuit between the posts, say wrenching at one post and wrench handle somehow touching other post or something connected to it. It happens.
    use stock battery or 100% compatible.
    Clean insides of cable clamps. Gently but firmly snug the clamp bolts.
    check voltage of the new battery. At store if possible. If store has an electronic load tester see if they’ll test it for you. You should be seeing at least 12.6 volts with a battery that’s been sitting in store for a while. And electronic load test it should show well above specd Cold Cranking Amps (CCA).
    Good to fully charge the battery with a decent quality smart charger. You can do this before or after install. Charger should not be more than 4~5 amp rating.
    #7 Mendel Leisk, Jul 18, 2023
