Preemptive Head Gasket Replacement? 2010 172k
Discussion in 'Gen 3 Prius Technical Discussion' started by tallassazn, Oct 14, 2021.
  1. tallassazn
    tallassazn Junior Member
    Coming up on 175k miles on this 2010 Prius which has been relatively easy to maintain. Shout out to Raytheeagle and friends for the meetups where we did an EGR cleaning/Oil Catch Can and another for a Coolant Flush/other fluids.
    The car sometimes rattles upon startup but it isn't really consistent. Had a few battery issues (non hybrid) and finally swapped in a new 12V Battery. I chalk those issues to possibly leaving the interior car lights on over night. At the last oil change, I did myself, I was a bit shocked but a little over 10k miles, there was about half of the oil remaining if not a little less than.
    Coolant looks full still. Oil in the OCC and when doing a change, looks black and dirty but not milky at all. OCC maybe needs to be dumped once a year if that.
    Just trying to ascertain if I should preemptively have the head gasket swapped out. A shop up in SAC quoted me $1200 to swap out the HG and machine/resurface the head. A shop down in Socal said $1k.
    Obviously people get on this board when there are issues. I'm just trying to see if its worth it to invest $1k preemptively vs don't fix what isn't broken. Its hard to get a read but what % of owners actually have this issue. I'm in the Bay Area, regarding weather/temperature, and while it may be foolish given the amount of CATs being stolen, I park outside and mostly drive freeway miles.
    Contemplating trying to sell the car or invest $1k in hopes that will allow the car to go another 150-200k miles.
    Appreciate any insight/perspectives.
    Raytheeagle likes this.
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Don't you have to address the real cause of the oil burning and head gasket failure though? The pistons, rings, and probably worn cylinder walls?
    A head gasket replacent won't address those issues.
  3. Ran4it2
    Ran4it2 Junior Member
    Lafayette, CA
    Clean your EGR cooler ASAP if you haven't already and at the same time install an oil catch can with a new PCV.
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,525
    6,608
    Texas Hill Country
    Its not really fix something that is not broken. Most head gasket leaks on these cars start small and rattle infrequent without obvious coolant leaks.
    However a head gasket won't get your 175k car to 325k-375k miles.
    If you changed the oil every 5k miles and only needed one quart each time, that is not terrible. A low cost head gasket might reliably get you another 30k.
    Personally I would factor in an engine rebuild if you think 150k-200k additional miles are necessary. Hopefully a brake booster or hv battery does not further skew the economics over the next 150k miles. You can almost count on the battery if its original.
    #4 rjparker, Oct 14, 2021
