Preferences for map direction
Discussion in 'Prime Audio, Electronics, and Infotainment' started by MNdriver, Jun 5, 2017.
  1. North is up (like a map)
    29.6%
  2. The direction you're traveling in is up
    70.4%
  1. MNdriver
    MNdriver Senior Member
    549
    577
    Just for fun - I discovered that you can change how your navigation screen is oriented. I'm having a hard time deciding which I prefer - north always on top or the direction I'm traveling in always on top.
    HPrimeAdvanced likes this.
  2. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,303
    3,519
    Anaheim, CA
    All right, dear woman, tell us Advanced owners the quick and dirty on how to do it! Call me lazy, but don't call me late for dinner!!
    Cetaman and benagi like this.
  3. MNdriver
    549
    577
    Ha! Well, I discovered it by accident. I can't tell you exactly, but it starts with pressing the N on the upper left part of the map..... You have 3 options for map orientation.
    I've been switching back and forth and always seem to prefer the one I don't have at the moment.
    49,500
    i don't know why, but i've always preferred north. i've changed it ti traveling direction a few times to try it, but found it confusing. maybe because i always held paper maps north oriented.
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,024
    Westminster, Colorado
    Where I'm pointing, tilted.
    mercat68 and YPizza like this.
  6. Pdog808
    Pdog808 Active Member
    416
    276
    Los Angeles
    2018 Prius Prime
    Too used to my Garmin where the direction I am moving is always "north" on the screen. Plus I think it's a video gaming thing that I'm too used to at this point.
  7. DavidA
    2,328
    1,812
    Chicago western burbs
    This option has been with us through all the Gen3 Prii since 2009, and perhaps earlier. It is only available to change when you're in Park. I use North-is-up mode when I'm far enough away that I might get lost, and North-can-move when I'm local and pretty know the roads and direction I'm actually traveling.
  8. ChapmanF
    15,629
    In my 2010, I like to use the split-screen mode, with the birds-eye view, 2 mile grid on the left (or even further zoomed out, on a long trip), with North up, and the right side showing a close up, several blocks view, with my heading up.
    I'm not sure which way I should answer your poll. :)
    -Chap
  9. Lee Jay
    5,850
    4,024
    Not in my Prime Advanced. I can change it at any speed.
    HPrimeAdvanced and DavidA like this.
  10. MNdriver
    549
    577
    I'm surprised that 'north up' is winning - just because I thought that navigation systems generally use the other approach. Then again, maybe I'm wrong about that. I've never had navigation before - just used my iPhone in my gen 2.
  11. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Question about the Prime map options: Is it possible to have it oriented pointing north AND have the location of your car at the bottom of the screen so that 50% of the screen isn't wasted? I've never seen a GPS that doesn't insist on wasting half the screen showing where I've already been unless it's in 3D mode.
    Edit thanks to @Lee Jay's helpful observation:
    Always north actually wouldn't work for having the pointer at the bottom. It theoretically could keep the pointer at an edge, always heading toward the center of the map, but that might be kind of disorienting as you make a turn and the map slides sideways to accommodate the new direction of travel.
    #11 jerrymildred, Jun 6, 2017
    bwilson4web likes this.
  12. Lee Jay
    5,850
    4,024
    That makes no sense. If it's pointing north, your car should be in the middle because you could be traveling in any direction.
    jerrymildred likes this.
  13. FuelMiser
    FuelMiser Senior Member
    1,300
    887
    Monument, CO
    I think I prefer the map to be oriented in the direction I'm going so I can easily determine whether the next turn will be to my left or right with a quick glance at the map. I know the lady says "turn left" or "turn right", plus there's an arrow pointing left or right, but if you haven't been paying attention, a quick glance is all you need.
    Bobdski, bresna and Son of Gloin like this.
  14. jerrymildred
    11,511
    14,113
    Tampa, FL
    You're right! Senior moment. It's the view that has your car alway pointed up that, on my gps, puts me in the middle when it doesn't need to. I guess what I really want it the map oriented stably and not spinning around as I turn, but keeping my pointer headed into the map rather than heading out from the middle. Hard to explain. Then again, that might need some rather gross and abrupt map movements as you make turns.
    Robert Holt likes this.
  15. Lee Jay
    5,850
    4,024
    If you're in up-is-where-you're-going view, just close sound and climate and touch anywhere on the map. That puts you at the bottom because it closes the bottom menu.
  16. jerrymildred
    11,511
    14,113
    Tampa, FL
    Nice! When I do that in my Garmin, it will work for a little while, but doesn't work quite right. I could live with the up is where you're going if it used the whole map. Otherwise, I stay oriented better if the map makes it clear which direction I'm heading. Thanks!!
  17. bwilson4web
    15,524
    A "U-turn" is unlikely so I would prefer the car be in the middle of either side or top. Of course it could become a little funny at the boundary condition of traveling at a 45 degree angle. Maybe a circular map? <grins>
  18. Lee Jay
    5,850
    4,024
    This is a road very near where I am right now.
  19. MNdriver
    549
    577
    WOW! Nothing like that in Minnesota.
    Son of Gloin likes this.
  20. Son of Gloin
    Son of Gloin Active Member
    421
    320
    Lafayette, IN
    If I'm looking at a map, I always want north up... but with a nav display, I very strongly prefer the direction I'm heading to be up. I find that aspect to be especially useful if driving on winding roads, most especially at night! Seeing it like that on a nav display helps me to "plan" for bends in the road as I approach them, which is a "detail" most maps wouldn't display anyway due to scale restraints.
    Prius from Dad and Bob Comer like this.
