Premium sound system? Only with ATP??
Discussion in 'Prius v Audio and Electronics' started by mangomegan, May 20, 2018.
  1. mangomegan
    mangomegan New Member
    Ben Lomond, CA
    We're looking to buy a used prius v, and are wondering about the sound quality of sound system. Hubby and I both really appreciate music, and would enjoy good sound. Are we out of luck if we find one without ATP? Is the premium sound only on models with ATP? Does that apply to all years, 2012-2017?
  2. Tideland Prius
    16,127
    Unfortunately, if you want the JBL audio system, you have to get the v Five ATP; that applies to all years.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,680
    Texas Hill Country
    The standard system suffers in bass and the rear speakers are nearly useless. Not to say that the JBL system will knock your socks off either. Its just fair but has better highs and midranges. The v also has a fair amount of road noise in the cabin with some surfaces and tires worse than others. Upgrading is difficult unless you interface speaker level inputs into an aftermarket amp and add new speakers, particularly in the rear.
    #3 rjparker, May 20, 2018
  4. Diemaster
    Diemaster Active Member
    290
    260
    so. cal
    This is true for any prius, IMO even the JBL systems. Lack of a good subwoofer. :D:rolleyes:
  5. Tideland Prius
    16,127
    At least with the Gen 3 (and I assume similarly the Prius v), I found the front speakers better than the rear. The rear sound tinny and the front sound stage sounds fuller.
    I know it's a different vehicle but it's something to consider when you're listening to the JBL audio in the Prius v.
  6. Offline
    Offline Active Member
    637
    230
    Lenexa, Kansas
    Whatever speakers there are in our 2012 Prius Five/ATP with JBL seem to do a pretty good job of emulating a subwoofer with plenty of base even when I'm streaming from Pandora via Entune.
    Don't buy a Prius if you want music quality while you drive - they're too damned noisy for that unless you are stopped with the engine not running.
  7. mangomegan
    Ben Lomond, CA
    Well, I am coming from a 1995 Subaru, so I'm sure it'll be a noise level I'm used to!
  8. Tideland Prius
    16,127
    I believe the Gen 3 and Prius v JBL audio systems have a "Distributed Subwoofer System".
    From cleanmpg.com
