Press Power Button w/o Brake--How to undo?
Discussion in 'Gen 2 Prius Main Forum' started by PriusSport, Jun 17, 2008.
  1. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    This has probably been discussed before, but, as a new owner, I would like to know what should I do if I press the power button (starting or stopping) and forget to hit the brake pedal first?
    Do you then repeatedly press the power button with the brake applied until you see the 'ready' sign on the dash? How about after stopping to turn off the power?
    I guess, if you hit the power button without hitting the brake pedal, you just hit the brake pedal and press the power button again repeatedly until you get to the 'ready' mode (starting), or until the power turns off (stopping). ??
    This will happen sooner or later, and I want to be ready for it. Thanks.
  2. slair
    slair Ubër Senior Member
    404
    Lafayette, IN
    If it happens, this is what you do.
    1. Put foot on brake
    2. Put finger on power button
    3. Press
    4. Enjoy!
  3. rsforkner
    rsforkner Member
    369
    Boynton Beach, FL, USA
    2014 Prius v wagon
    Been there, done that,
    What slair said...
    B
  4. PriusSport
    1,498
    88
    SE PA
    Sounds like you just hit the brake pedal and press the power button again--either starting or stopping. That's simple enough. Thanks.
    Wish they would cover this in the manual.
  5. richard schumacher
    7,663
    1,038
    United States
    Press brake pedal firmly and press the power button carefully and deliberately. Hurrying and stabbing at the thing can get people tied into little knots.
  6. Winston
    Winston Member
    614
    SF Bay Area, California
    I have a little pet peeve with the power button. I often push it to turn off the car and it does not work. I push it firmly enough, but too quickly. There seems to be a minimum time that it has to be depressed in order to turn off the car. It is a very short time, but there is some sort of minimum. Bah....
  7. nosliw
    nosliw New Member
    76
    PNW
    on a related note-
    how can one get out of ACC and into OFF without booting the damn thing up?
    if i'm listening to the radio do i have to turn the car on and then off again?
  8. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    Just press the power button without stepping on the brake pedal. The system will power down.
  9. tombellanca
    tombellanca New Member
    53
    Encinitas, CA
    the morning after buying my Prius, I went out to start the car and as I learned later, did not press the break. I was convinced I was sold a lemon and if it wasn't for a breakfast date I probably would have called a tow truck then and there.
    Luckily after breakfast, I tried to re-start it, this time using the break and was on my way.
  10. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    I keep hearing the words power button brake and stop... you don't have to use the brake to turn off the car... once you press the park button.. all you have to do is hit the power button... If you are stopped and you hit the power button, the car will park itself and power down. If you're above a certain speed, the car locks out the Power button until you HOLD it down for 3 second.. then it goes into aux mode (everything except radio, and simple steering and braking)... ...just in case the hybrid system ever freaks out when driving...
    the park button works up till 8mph.. after that it shifts to N.. same for the rest of the gears..... well... reverse...
  11. rsforkner
    rsforkner Member
    369
    2014 Prius v wagon
    Kind of scary that you know that for a fact. :D
    B
  12. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    The park button works up to *2* mph. Two. I know that because
    I tried it in an icy lot where locking the front end wouldn't
    have mattered. Somewhere between 2 and 3 on the speedo, the
    car laughed at me and went to N instead. 8 MPH would be plenty
    fast enough to tear things up inside the tranny.
    _H*
  13. hiremichaelreid
    hiremichaelreid New Member
    451
    Ottawa/Aylmer, Canada
    I
    I think you have to hit it twice from ACC to OFF. IGN-ON (to allow windows to open, AC on, etc) is between those positions.
    My basic rule is just keep hitting power button until you get the mode you want. Except for driving, where you must also step on brake.
    I've been annoyed by the "debounce time" on the power switch. Sometimes I want to adjust the windows from power-off and must hit it twice, BUT with a pause between the two hits, and the "hits" are more like "half second hold downs".
    Anyway, Prius probably isn't the best car for quick "bank robbery getaways".
