Pressing P (the Park Button)
Discussion in 'Gen 4 Prius Main Forum' started by rahmani, Feb 8, 2021.
  1. rahmani
    rahmani Junior Member
    Bangladesh
    Is it okay if directly press the Park Button 'P' when the car is in 'D' but sitting idle in traffic?
  2. Tideland Prius
    16,623
    Yes, it is ok. It is similar to a regular automatic transmission car and shifting that car into Park from Drive.
    rahmani, krmcg and alanclarkeau like this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Only thing is to be ready to 1) foot on brake; 2) put in "D" - just before you need to move.
    rahmani likes this.
  4. Mendel Leisk
    41,925
    Below some speed threshold it’ll shift to Park, and above that threshold it’ll ignore you. That said. I don’t think it’s good to do this: in particular if you’re just under the threshold, I think that shift to Park would stop you with an unhealthy jolt.
  5. ChapmanF
    18,569
    Does it ignore you, or beep twice and pick Neutral?
    I know if you pick R from D, above a certain threshold you get the two beeps and neutral.
    Or at least that's what Gen 3 does.
    I guess that's where we assume they chose the threshold somewhat reasonably. Limbers up the ol' motor mounts. :)
  6. alanclarkeau
    7,045
    7,593
    That doesn't happen on a Gen 4.
    As long as you're stopped, you need to hit "P" button - it won't do it by itself below some speed threshold.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    I would do what's customary in Bangladesh if I was driving there. It certainly won't hurt the car. Around here it might generate a few horns and upraised middle fingers (or worse) while you press the brake, put it in Drive, and move your foot to the accelerator pedal.
    Not as bad though as what I see almost every day here. Sitting at a green light messing with your phone till one of the drivers behind the one in front happens to look up from their phone and see the light turning yellow.
    rahmani and alanclarkeau like this.
  8. rahmani
    Bangladesh
    Thanks
    Hahahahah, well said
    #8 rahmani, Feb 9, 2021
    jerrymildred likes this.
  9. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    Yes, another option if you have the DRCC is to engage it and it will go into waiting while stopped behind someone else. Works great for drive thrus also!
  10. alanclarkeau
    7,045
    7,593
    Yes - as long as there's someone in front of you.
    rahmani, robsnyder20 and jerrymildred like this.
