Pressing Power in Drive
Discussion in 'Gen 2 Prius Main Forum' started by km5er, Jan 31, 2006.
  1. km5er
    km5er New Member
    50
    Charlotte, NC
    :( I was wondering if anyone has pushed the power button when the car was being driven. What happened? Nothing (Because Toyota guarded that function) or oops the car just turned off?
  2. bnlfanmatt
    bnlfanmatt Member
    253
    Southwest suburbs of Chicago
    At the slightest movement, it does nothing (tried it once while doing 3 or 4mph.)
    Luckily...
  3. DocToss
    DocToss Junior Member
    69
    Cordova, TN
    I thought I read somewhere if you press and hold the power button while the engine is on, it will disable the electric engine.
  4. kellymarquette
    kellymarquette New Member
    I read that too, in the manual. The key is that you have to hold it in. If you just bump it or press it quickly it won't do anything.
    Not that I'm going to attempt it....
  5. KMO
    KMO Senior Member
    1,544
    429
    Finland
    2023 Prius Prime
    I've done it. Holding it for maybe 3 seconds appears to throw you into ACC mode - the dash goes blank, the light on the button goes green, the engine cuts out, and you lose power steering. Braking didn't seem too badly affected - I didn't really notice.
    As a possibly unhelpful quirk, the drop to ACC mode also turns the headlights off! This may be different in the US - here in Europe turning the car off noramlly turns off the headlights, leaving the position lamps on. Presumably turning the switch off and on would have reactivated them.
    The state it leaves you in is interesting - you're in ACC mode but in N. The gear indicator showing N is the only thing left on the otherwise blank dash. You can't move to D or R, and as soon as you move to P, the gear indicator on the dash vanishes, leaving you in normal ACC mode.
