Pretty sure this has been asked before...
Discussion in 'Generation 1 Prius Discussion' started by Scottveazie, Aug 7, 2017.
  1. Scottveazie
    Scottveazie New Member
    PNW
    2003 Prius
    So I got an 03 Prius in trade for my Saab about 3 months ago. As far as I can tell, it's the original HV battery with 203k on it. Runs, drives fine, still about 42 mpg in mixed driving with lots of rush hour stop and go. My main concern is, how much longer can I realistically expect the Hv to last? I don't want to pop for a new one, I don't like the gen 1 nearly as much as the gen 2. It's a fine commuter but I'm not sure it's work putting serious cash into if the HV dies.
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,508
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    This question is frequently asked, but if you are willing to invest a small amount, the HV battery can be grid charged and extend the packs life;).
    I have done this with our 2010 Prius II with 160 k miles. Havin performed grid charging, I have seen the benefits and will continue to do so:
    Prolong Battery Systems. Extending the life of your hybrid. – Hybrid Automotive
    Hope that helps(y).
  3. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    Most likely will need the bus bar connections cleaned up as well.
  4. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    Grid charger for a Gen 1 is $500 to $800, depending on what you choose to do about the discharging part. I have the one with the smart discharger, haven't used the smart discharger yet because it came after the really hot weather arrived. One of my Pri's has the original battery pack, the other has 4 year old factory replacement. Both will get grid charged this fall.
    If I were you, I'd go ahead and sell the car while it's running well. Get what you want, with the thought that any (every) car eventually wears out. Even Gen 2's do. The batteries in the early Gen 2's are pushing 15 or so years, too.
  5. bobofky
    bobofky Member
    107
    My experience with four Gen1 Prii is HV battery lasts for about 8 years. Time is more important than miles.
