Prevent ICE starting in cold weather
Discussion in 'Gen 5 Prius Main Forum' started by Nick Abbot, Dec 18, 2025 at 2:41 PM.
  1. Nick Abbot
    Nick Abbot Junior Member
    New York
    2024 Prius Prime
    XSE
    I have a 2024 Prius Prime. Is there any way to prevent the ICE starting up in cold weather?
    I've noticed when the weather/battery is cold, the engine will start while in electric mode, presumably to warm the battery. This the exact opposite of what I wanted this car for.
    I would love to know of any way to prevent the engine from running when the battery is cold.
    My commute is about1500 feet. In cold weather the engine starts about 100 feet from my driveway.
  2. Gorgonzola
    Gorgonzola Junior Member
    38
    22
    New Hampshire, USA
    2024 Prius
    LE AWD-e
    One solution might be to bundle up and walk the 1,500 feet. I’m not an owner of the plug-in but I suspect those systems are automated based on the car’s diagnostics and not something you can override.
  3. Mendel Leisk
    41,483
    1500 feet is 500 yards: 5 football fields end to end.
  4. fuzzy1
    10,463
    At what temperatures are you seeing this? What fraction of mornings is it cold enough to force this mode?
    I haven't had my related '24 RAV Prime out in much serious cold yet (missed most of last ski season due to injury), so haven't learned all its temperature thresholds. While traveling, only once has it been started in cold enough conditions to immediately bypass EV mode and go straight to HV, probably +4F that morning (?). On several morning in the teens, I needed the front defrost to melt off the windshield before moving, also forcing the ICE on. But garaged at home in a milder coastal climate, haven't yet dealt with unwanted ICE operation, it doesn't get cold enough here every winter.
    I also haven't yet run into the "100 feet from the driveway" threshold in this RAV. In my previous Gen3 Prii non-plug-in, that threshold (actually, 10-15 seconds from start) was 68F.
