Preventing Catalytic Converter theft
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by enginestarter, Apr 2, 2019.
  1. enginestarter
    enginestarter Junior Member
    66
    UK
    Active
    I'd seen a few videos how thieves come with a portable grinder and jack - and take off in less than 60 seconds.
    I know someone close to me who very recently had theirs stolen
    It was an 09 reg, similar to my car.
    What measures can I take to prevent?
    I've seen online a chain thing you wrap around.
    That did seem like a lot of work + I was thinking if that added unnecessary weight onto something not expecting to take that weight load?
    Just looking for some thoughts and advice.
    Thanks.
    MasterPri08 and Scully like this.
    49,796
    i would start by reading the several cat theft threads. maybe some 360degree camera's?
    the wrap around stuff shouldn't be very heavy. someone from LA posted a pic of a metal grid bolted underneath. don't know how effective either is.
    i suppose if there are enough pri around, they might just move on to another car?
    what about an active proximity theft deterrent system that would sound the horn if someone touched the car?
  3. enginestarter
    66
    UK
    Active
    @bisco i didn't realise it was an epidemic until recently.
    i know someone else with a fairly new Prius, they had an attempted theft.
    The damage can't be repaired they have been told. Fortunately they can still drive OK.
    (I think that sucks - OK, 10+ years ago, car was new... Toyota missed thinking about theft - but many many years later, they should have better design to stop theft so easily)
    I'll definitely read around as you suggest...
    Metal grid? Proximity theft deterrent?
    I thought there would be established ways of protecting?
    I'd rather go with tried and tested and recommended by the mass methods...
    Do we not have a consensus of the best method(s)?
    Thanks.
    49,796
    not that i recall reading. it may be more difficult than you perceive. see the london prelims, especially the thread by @Data Daedalus edit: sorry, @Priusinlondon
    there are even video's of the thieves doing the dirty deed.
    #4 bisco, Apr 2, 2019
  5. bisco
    49,796
    as for toyota, i doubt they care, more cat sales.
    SFO likes this.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    Something like this is probably your only practical choice.......with the sensitivity set down low enough that it wouldn't trigger until something as drastic as jacking the car up happens.
    It would need something louder than just the stock horn......because those things can go off for HOURS before anybody pays any attention.
  7. sam spade 2
    7,035
    2,790
    2017 Prius c
    Apparently not.
    Would you care to venture a guess at what might be required ?
    If the thieves are armed with a high speed grinder or a torch what do you think might be a deterrent ??
    Hint: There probably isn't one that would be reasonable.
  8. maf
    maf Junior Member
    I'm thinking a sticky gooey substance could be painted on the catalytic converter making it inconvenient to handle. You would need something that doesn't interfere with its normal operation or drip off, but made it a pain to deal with. Anti-climb paint might do it.
    Scully likes this.
  9. sam spade 2
    7,035
    2,790
    2017 Prius c
    Guess you don't have much experience with CAT converters.
    They get VERY HOT and that idea would only apply until the first time the vehicle is driven.
    And then your "substance" might catch fire.
    Skibob likes this.
  10. Mendel Leisk
    38,952
    Someone just this morning in another thread mentioned CatStrap. It appears to be readily available in the States, but up here in Canada searching amazon.ca all I got was pictures of cute cats wearing straps. :confused:
    Catstrap is a stick-on kevlar belt with internal steel cable that'll roll. And a warning label.
  11. Kaptainkid1
    Kaptainkid1 Active Member
    308
    243
    Los Angeles
    I attached 4'x 6' metal grate under the chassis blocking the Catalytic converter and metal tapping scews to floor rails under car and she's stay put and no one has stolen my cat yet. $35 in parts. Also I used large washers to hold the grate to floor rails. I came up with this solutions after 10 prius on my block had the Catalytic converters we're stolen in one night. Also since I have that many more easier targets they will skip me the next time too.
    SM-J737T1 ?
  12. pasadena_commut
    pasadena_commut Senior Member
    1,603
    479
    Southern California
    Does the metal touch the cat? If it does it could cause a few issues. It would act like a heat sink and might result in the car burning a little more fuel in order to keep the cat at operating temperature. (Conversely a solid shield might trap heat and cause issues in the other direction, but this one is full of holes.) If the cat or car body is a dissimilar metal (for instance, aluminum) galvanic corrosion could occur at the contact points.
    What size screws and washers? I have never seen security heads on metal tapping screws, so what is keeping the thieves at bay? Some combination of not wanting to take the time to remove all the screws and fear of the unknown? As in, who knows what else might be under there, best to look for another victim. Must be mostly the latter, as I suspect that a power screwdriver could remove all those screws in about 1 to 2 minutes. The grinder they are going to use to cut the pipe should also be able to remove the screw heads in a similar amount of time.
  13. meeder
    meeder Active Member
    239
    162
    Doesburg, The Netherlands
    Every delay has a preventative effect.
    It's the same as with the locks on your house. You don't need the best locks available, they just have to be better than the locks at the neighbors.
    Thieves don't want to go to a lot of trouble of getting to the item they want. If they see a metal shield under the cat they will most likely look elsewhere.
    Verstuurd vanaf mijn LYA-L09 met Tapatalk
    donbright likes this.
  14. Rmay635703
    Rmay635703 Senior Member
    2,603
    1,617
    Somewhere in Wisconsin
    2013 Chevy Volt
    Personally I would remove my cat and replace it for each inspection
    can’t steal what isn’t there.
    2Fats, ETC(SS) and jzchen like this.
  15. Kaptainkid1
    308
    243
    Los Angeles
    Watch a 'pit crew' of parts thieves steal the exhaust off a Prius | Get the latest car news, car reviews, auto show updates, and racing news from Autoweek. News for the auto enthusiast.
    These thieves didn't use a grinder and your right if these guys used the grinders or had a dewalt screw driver they can steal my cat no problem. These thieves used: 20v reciprocating saw and car jack. It seems it's tools and methods.
    Second question the grate doesn't touch the cat. Its easily 3 inches a way from the cat. My car has been passed up in by thieves and I'm guess because they don't have those tools when stealing cats. I used a flat washer 1 in wide and metal self tapping screws. I did drill a small hole first so the screws can tap the bottom rail easier. Also if you need work done on your car this grate can be removed for service.
    I dont promise this method will prevent a thief from stealing your cat all I can say I put this grate on two Prius. These two cars still have their cats and it's been 3 years now in total. If people want to steal my cats they will need more tools. Good luck with a cheaper method. Only wasted $35 and crossing fingers it's been working so far.
    SM-J737T1 ?
  16. pasadena_commut
    1,603
    479
    Southern California
    Thanks for the info.
  17. goku2
    goku2 Junior Member
    SFBayArea
    Have any more pics of your work? Which sized screws, washer, etc. did you use/buy. How/what did you use to cut the mesh?
    SFO likes this.
  18. Kaptainkid1
    308
    243
    Los Angeles
    I'll do a "how to" write up tomorrow with more photos and details you're requesting but honestly I've been attacked by online haters and it makes feel unappreciated and a waste of my time.
    I don't promise your cat won't get stolen but my block has 10 Priis and one night all ten got hit. The second time it happened but my Prius was modded with this grate it didn't get stolen and they went after the other 9 easy targets. So take this wisdom with a grain a salt. I have to jack up my car and do measurement for proper write up.
    SM-J737T1 ?
    #19 Kaptainkid1, Dec 14, 2019
    Redbot and SFO like this.
  19. goku2
    goku2 Junior Member
    SFBayArea
    I've been told spray painting the catalytic converter with BBQ grill paint will also help deter thieves. So maybe painting them and doing that mesh would be a good idea.
