Preventive maintenance at 96k km
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Ohid, Feb 13, 2022.
  1. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Prius v/Alpha 7 seater
    Year 2015
    ODO: 96k km not miles
    80k in Japan, 16k km in Bangladesh in 2.5 years
    Spark plugs and Transmission fluid changed at 83k km in 2.4 years ago.
    Maintain regular schedule of Maintenance
    No issues except burning gas smell at cold start. Here cold stayed at 15-22°C.
    Optimum Performance and got better mileage than recommended in highway so far.
    Driving pattern: mostly city drive. Only completed stage 2 cycle in engine warm up in my regular commute. Out of 16k km, only 3.5k km was highway drive.
    For preventive maintenance, should I go for cleaning EGR system, Intake manifold and changing Coolants and Brake fluid. Or I wait another year.
    Give suggestions from your experience.
    -TIA
  2. ColoradoBoo
    ColoradoBoo Senior Member
    964
    631
    Monument, Colorado USA
    Yes, I'd change the coolant if it hasn't been done. If the brake fluid hasn't been flushed I'd also do that. At every 40,000 km, I'd clean the MAF sensor and throttle body.
    Ohid likes this.
  3. Mendel Leisk
    38,728
    Yes, now's a good time.
    Toyota USA says 100K miles or 10 years for engine coolant first change, and 150K miles or 15 years for inverter coolant first change. Toyota Canada (my country) says 100K miles (160K kms) or 10 years for both.
    Toyota USA says nothing, and Toyota Canada says 30K miles (48K kms) or tri-yearly. There is a relatively easy for do it yourself method for this outlined in the Repair Manual, does not require Techstream. And a Techstream method.
    More info in all of these in my signature.
    Ohid likes this.
  4. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Throttle body cleaned last week. Coolants and brake fluid not change yet.
  5. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Thanks for your suggestions. What precaution or preparation should I take before cleaning EGR and intake?
    #5 Ohid, Feb 13, 2022
  6. Mendel Leisk
    38,728
    There's one nut on a bracket on the underside of the EGR cooler that's a royal pain to access. It just takes time, trying different sockets and extensions. I would recommend to take that off in advance (days, weeks in advance), and leave it off. There's plenty of fasteners holding the system. If you're ambitious, back out the stud that nut goes onto, as well (E8 Torx socket required). Or do that when the system's completely removed, and again, leave it off. You don't need to remove anything else to get to this nut, and it's a real time waster to access, so doing it first is a good overture.
    Gather all the tools you'll need. You don't need to disconnect either battery. I would recommend to have the front of the car raised and safely supported, and the engine's plastic undershield removed.
    For more info, tool list, strategies with coolant, read through the first link in my signature.
    Ohid likes this.
