Pri gen 2 MFD problem
Discussion in 'Gen 2 Prius Audio and Electronics' started by Gen2khar, Dec 7, 2024.
  1. Gen2khar
    Gen2khar Junior Member
    Uk
    Hi have 2006 Prius and I noticed when I press the either buttons on the mfd it won’t beep any more, I have the screen without navigation
    Any help is appreciated
    Thanks
    51,011
    you'll probably need to replace it, unless you can find an electronic repair shop willing to tackle it
  3. pasadena_commut
    pasadena_commut Senior Member
    2,215
    661
    Southern California
    Google for:
    prius mfd repair services
    and it will list some companies which repair these devices. There are also some on Ebay for about the same price, but be careful if you go that route that the one you get is exactly the same type as the one you currently have.
  4. Tombukt2
    Tombukt2 Senior Member
    11,994
    2,119
    Durham NC
    But other than the beeping everything is working as it should I'm not sure that mine beeps when I push the buttons on it now I have to go out and look but I have every beep that I possibly can turned off in the car's menu I'm trying not to hear any beeps I don't think my MFD does any beeping but every button and every position on the MFD works every component in the car so far like it's supposed to I've got the vents hunting up and down in the air blower system but other than that everything's working perfectly but I'm sure I have no beeps
  5. dolj
    dolj Senior Member
    8,182
    4,167
    Wellington, New Zealand
    I'm pretty sure there is a switch in settings to turn the beep on or off.
  6. Gen2khar
    Uk
    I have tried the settings to turn on and off the beep but still not working
  7. Tombukt2
    11,994
    2,119
    Durham NC
    But the MFD fully functions other than a beep . Very special types have to have it maybe do not know.
