Prime 2017 max speed?
Discussion in 'Prime Main Forum (2017-2022)' started by mveras1972, Aug 15, 2021.
  1. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    Does anyone know what’s the Prime’s top speed? Without a dial, I can’t tell what would be it’s top speed. I’ve had this baby hit 100mph without an issue.
    iPhone ?
  2. schja01
    schja01 Senior Member
    1,833
    1,221
    Chicagoland
    2024 Prius
    Limited AWD-e
    I think I’d worry about the tires before the car maxing out.
    pghyndman likes this.
  3. Salamander_King
    Salamander_King Senior Member
    11,019
    8,953
    New England
    I suspect the max speed is much higher than my ability to safely drive a car. I certainly have hit >90mph on very rare occasions on the interstate in the past, but anything above that I would be risking my and others' lives. Not worth testing it.
  4. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    103 mph... witnessed firsthand.
  5. meeder
    meeder Active Member
    239
    163
    Doesburg, The Netherlands
    Aren't they all limited at 112/113 mph?
    Just about all Toyota hybrids here in Europe are limited to 180 km/h.
  6. schja01
    1,833
    1,221
    Chicagoland
    2024 Prius
    Limited AWD-e
  7. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    See this is why I’m asking because I don’t want to test the limits. But when I got it to 100mph it seemed like it would have gone beyond 100 with no issue. Very smooth. I don’t want to try it again though.
    I figure it has to be an electronic limit set at the computer, not some mechanical limit. Regarding safety, why would Toyota set a speed limit so high that it is very dangerous for the stability of the car? I would think it is safe enough given you’re on a smooth straight path free of debris or paving defects, though I would not take my chances. The police wouldn’t like it and secondly, any imperfections on the road could be a real danger.
    iPhone ?
  8. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Ummm... if you're interested in speed, are you sure you bought the right car? Just sayin'.
    Perhaps I'm an old fart, as I also own a Mercedes SL and Mercedes Coupe but have no desire to push either to 100 (in any event they are electronically limited to ~149 mph in keeping with their Z tire rating).
    But hey, whatever floats your boat.:eek:
  9. fuzzy1
    10,452
    Is that 180 km/h as displayed on the speedometer, or internally as read via the OBDII port, or on a GPS?
    Considering that the speedometer has an intentional offset or bias, and that European and North American speedometers are often biased differently, this makes a difference.
  10. meeder
    239
    163
    As mentioned in the specifications by Toyota. On the speedometer it goes past 180.
    fuzzy1 likes this.
  11. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    It’s really nothing to do with being interested in speed. It’s just an interest in knowing the limits of the Prius.
    iPhone ?
    privilege likes this.
  12. privilege
    privilege Active Member
    659
    169
    Birmingham
    I got curious and allegedly saw 100 on the gps. allegedly.
  13. douglasjre
    douglasjre Senior Member
    2,180
    718
    Null, NL
    116mph and you can leave it there all day. Engine temps go up to 205F in 90F weather. Economy goes down to round 28mpg
  14. OptimalPrime
    OptimalPrime Member
    161
    94
    Keene/Nashua
    I'm not sure what car you're referring to, but it's pretty surely not a 2017-2022 Prius Prime. It accelerates well to 104mph indicated, then acts like you had set the cruise control to 104. One time I saw 105 for under 1 second. As for mpg, here is my experience: 61mpg@61mph; 42mpg@84mph; 32mpg@96mph; 26mpg@104mph. Obviously very dependent upon weather, wind, tire inflation, etc. I run 50psi at all 4 corners, on 51psi max tires which are also XL 99T and winter rated. Yes, snow/ice tires rated for 118mph while carrying the weight of a minivan, on a Prius Prime run at high speed in hot western states in summer, while beating EPA mpg at normal speeds.
    So, my own observations are quite close to those of John1701a who says he witnessed 103 as the limit, though I've personally never failed to accelerate right past 103 and have it level off at 104 indicated. Same result with different sized tires, also. Some where actual speed was lower than the 104 indicated, one where actual speed was higher than the 104 indicated.
    douglasjre likes this.
  15. OptimalPrime
    OptimalPrime Member
    161
    94
    Keene/Nashua
    Every Prius and Prius Prime through at least 2022 came with tires with a very normal S speed rating, meaning they're fine to 112mph if properly inflated. Personally, I'd never do a speed run with tires at less than 42psi, and preferably right up near the "max psi at max load" pressure. I don't buy tires for a Prius or Prius Prime where that max pressure is anything but 50-51 psi. Then I run them at 50psi (cold), though for anyone used to driving on squishy tires at 35psi, you might want to work up to that as you learn to drive a car that isn't grossly understeering.
  16. sylvaing
    sylvaing Senior Member
    1,210
    514
    That's not something I would like to test here. That would be called reckless driving with an hefty fine, more demerit points than what a clean permit is allowed to have, a permit suspension (obviously) and an on the spot impound vehicle. Now cause an accident because of this and it's jail time (if you're out of it alive).
  17. fuzzy1
    10,452
    You must have experienced less de-policing up there than we have down here over the past four years.
  18. sylvaing
    1,210
    514
    There have been crackdowns lately and many got caught.
  19. Washingtonian
    Washingtonian Senior Member
    726
    621
    I remember reading somewhere that the maximum speed under battery power only is 85 MPG. Is that correct?
  20. douglasjre
    2,180
    718
    Null, NL
    Sorry I was referring to a 3rd gen
