Prime 2023 12V battery integrity on EV
Discussion in 'Gen 5 Prius Technical Discussion' started by hb06, Apr 13, 2023.
  1. hb06
    hb06 Member
    550
    Huntington Beach, CA
    On the new Prius Prime 2023, when almost exclusively driving on EV at 40 EV miles per day, how do you keep the 12V battery charged and from being depleted if not running the gas engine? Does the traction battery trickle to the 12V battery when driving on EV?
  2. JoeBlack
    JoeBlack Member
    112
    89
    Europe
    2021 Prius PHV
    I suspect it is the same for pretty much every EV / hybrid out there - they do not have alternator, they use traction battery to charge 12V battery.
    Jack90210 likes this.
  3. Gokhan
    Gokhan Senior Member
    6,676
    2,650
    Paramount CA
    On the Prius, the ICE does not charge the 12-V battery, as there is no alternator. The 12-V battery is charged by the high-voltage battery. Note that the car needs to be in the READY mode for the 12-V battery to be charged.
    Likewise, the 12-V battery does not start the ICE, as there is no starter.
  4. Trollbait
    12,797
    Plug ins, and some hybrids, use a DC to DC converter to step the high voltage coming out of the traction battery down to 12 volts power all the those accessories in the car. This will also charge the starter battery. Of course, the car needs to be in Ready mode or fully on for the traction battery to supply energy to the converter. So an EV chargers up the starter battery while it is driven, just like an ICE car.
    The PP will also charge the 12 volt battery while the car is actively charging. Not sure if it is at just a maintenance rate or while increase its state of charge though.
  5. Robmoo
    Robmoo Junior Member
    55
    2024 Prius
    They still haven't gotten rid of the 12v battery? What a PITA! On my Gen3 it was a small battery in the trunk. It lasted 8 years and was old $40 to replace. In my Gen4 it is a $200 battery under the hood that lasted just 4 years. Where is the 12v battery in the Gen5 and how expensive is it to replace?
    Alessandro_Ibi likes this.
  6. aforkosh
    aforkosh Active Member
    413
    272
    Oakland, CA
    2023 Prius
  7. aforkosh
    413
    272
    Oakland, CA
    2023 Prius
    It's back in the hatch (right corner near the door). I don't know the replacement cost
  8. bisco
    52,731
    where did you get a battery for $40.? i paid $200, in 2018, and most here have paid similar
  9. Hammersmith
    Hammersmith Senior Member
    2,431
    2,494
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yep. I think I paid around $175-$185 in late 2021. Or maybe I'm misremembering and it was over $200(I was in a hurry at the time). It's currently $239 MSRP at Toyota dealerships for a gen3.
    Doing a quick search, I'm seeing a low of around $240 for a few brands of battery and almost $300 for an Optima.
    #9 Hammersmith, May 4, 2023
  10. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    There is a vast number of reliable, well tested parts that use 12 volts. Did you really want to pay for "hybrid" bulbs instead of 12 volt bulbs?
    Also the 12 volt battery does POST safety checks before allowing high voltage in your car. This seems wise.
  11. nagrath
    nagrath Member
    145
    49
    Putnam County, New York
    2023 Prius Prime
    XSE
    Was wondering this myself, as my 12 volt battery just failed in my 6mo old Prius Prime. I asked my Toyota service rep if the car charges the 12v battery in EV mode, since I drive most days in EV. He shrugged his shoulders. They replaced the battery under warrantee but I do hope this isn't an issue with the car if I keep driving in EV mode. Oddly, the battery ALSO failed on my old 2013 Gen 3 this morning - I had asked my son to pick me up from the dealer! It's charging now but taking a long time to charge - it's only a year and a half old, so it might be bad, too! Crazy. But also under warrantee.
  12. Mr.Vanvandenburg
    1,359
    633
    2020 Prius Prime
    A battery monitor makes it easy to tell what the battery level is, and when it’s charging. I found taking off an old aftermarket cruise control on my 96 Toyota solved the parasitic drain loss. The monitor tells the voltage while driving and when turned off in real time. I have seen no drain issues from the monitors themselves.
    Two battery monitors using the same app could show the soc and voltage of both car batteries on your phone on the same screen. Have to be within 10 feet or so to start the bluetooth connection.
    #12 Mr.Vanvandenburg, Jan 3, 2024
  13. KMO
    KMO Senior Member
    2,022
    744
    Finland
    2023 Prius Prime
    The 12V battery can be charged from the high-voltage system whenever the system is in READY mode, same as any Prius since 1997. The Prius has always had a lot of measures taken to cope with the engine not running, and this was there on day one. Many of the plug-in or EV problems like that were solved some time ago - the Prius was a testbed for such stuff.
    In the Prime, the 12V battery can also charge when the on-board charger is active and drawing power from the charging port - so either charging the battery, heating it, or being in "My Room" mode.
  14. BiomedO1
    BiomedO1 Senior Member
    4,463
    2,350
    Left Coast
    He must've dropped in a small cheap Home Depot lawn mower/tractor battery.:eek::D:oops::rolleyes:o_O
  15. nagrath
    nagrath Member
    145
    49
    2023 Prius Prime
    XSE
    OK, I realize I am a relatively new Prime owner, but I've not heard anything about "heating" the battery or "My Room" mode. Is this in the 2023, or the previous model?
  16. Gokhan
    6,676
    2,650
    Paramount CA
    As long as the car sees regular long trips—regardless of the EV mode—and you don't sit in the car unless the car is in the READY mode and you don't leave the AC charger plugged in for longer than overnight, you shouldn't have 12-V-battery issues.
    Possible replacement alternatives:
    Walmart EverStart Maxx 140R or EverStart Maxx H4
    ACDelco AGM EN1
    Toyota TrueStart H4
    I know for sure that the Walmart EverStart Maxx 140R comes with the required drain holes on either side and a drain plug for the unused drain hole; so, it is a solid choice for a trunk-installed battery with a drain hose attached.
    PrimeDan likes this.
  17. KMO
    KMO Senior Member
    2,022
    744
    Finland
    2023 Prius Prime
    Heating's in both - when you're plugged in and the charging schedule permits, it will draw power into heater elements to keep the battery above about 5°C/40°F to improve performance when you start. That has a 3-day timeout. It's an option somewhere in the menus, and on by default - you'd only turn it off if you were worried about the electricity billing. (It would be pretty minor if purely on kWh).
    "My room" mode is prompted if you go into ACCESSORY or POWER ON mode when plugged into the charger - it will draw power to run the car's accessories, including ventilation. That's new in 2023, I think.
    Both are in the manual. Don't have US page numbers, but probably section 2.2 - Charging > Charging methods > Charging-linked functions.
  18. vvillovv
    vvillovv Senior Member
    4,336
    1,517
    NY
    In the Prime is doesn't matter if in EV or HV or HV Auto mode, the 12 volt gets changed the same way. It also gets charged when plugged in, while charging the traction pack and sometimes when plugged in and using accessories like pre-conditioning and or the traction pack heaters.
    And trickle charging at 14.5 - 15 volts,. is really all that ever seems to happen, which is why (I think) the 12 volt never gets much above 12.6 volts, ever, and more likely hovers around 12.2 volts static, unless it is manually re-charged.
    #18 vvillovv, Jan 5, 2024
  19. Mr.Vanvandenburg
    1,359
    633
    2020 Prius Prime
    I have monitored the 12 volt and it doesn’t charge during traction battery charging. It does charge to 100% when in ready mode, but can be sort of slow and sometimes, often, it stops charging well below 100%. Most of the time voltage fluctuates very often with every change going on to the car. The monitor has a graph reading in essentially real time, every tiny or large dip and rise in voltage is displayed.
    After car is turned off the graph shows the battery voltage, and wherever it goes to the second. The rate of change is also seen by the slope of the voltage readings.
    This is for a 20 Prime, not a 2023.
    #19 Mr.Vanvandenburg, Jan 5, 2024
    Gokhan likes this.
  20. nagrath
    nagrath Member
    145
    49
    2023 Prius Prime
    XSE
    Thanks!
