Prime 240v charger
Discussion in 'Prime Main Forum (2017-2022)' started by JaymzB0nd, Mar 20, 2018.
  1. JaymzB0nd
    JaymzB0nd Junior Member
    68
    CA
    Hi. I just purchased a Prime yesterday and noticed today when attempting to charge it that it only has a plug for a standard electrical outlet. Where do you recommend getting a 240v charging cable or adapter for this car? I already have a 240v outlet in my garage.
  2. krushmoto
    krushmoto Member
    65
    44
    US
    Congratulations. I searched "level II ev charger" on eBay and purchased one for about $230. Should be cheaper now.
    Works great and charges my car in half the time.
    Nexus 6P ?
  3. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
    While 110 volt has a nice standardized plug, 220 has a bewildering array of choices.
    If you have a 220 outlet already, you can match that receptacle, but if you are having an electrician install one, you have choices.
    My daughter is considering an outlet in her garages ceiling, so I am leaning toward a L14-30 as it is a locking plug, won't fall out.
    amazon.com/Charger-Portable-Electric-Charging-Compatible/dp/B0758TLC8H
    amazon.com/ClipperCreek-LCS-20P-SAFETY-CERTIFIED-America/dp/B06XYR4X1W
    amazon.com/Maxgreen-Adjustable-Portable-Electric-Compatible/dp/B073ZCFLMB
    amazon.com/Level-Portable-Electric-Vehicle-Charger/dp/B018A6QK7C
    amazon.com/dp/B075GHTW86/?coliid=I2LAJE84DYY183
    I do not feel any plug is 'better' than another, I hope these show you some of your choices
    DTS likes this.
  4. JaymzB0nd
    68
    CA
    Great thank you both very much.
  5. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
  6. krushmoto
    krushmoto Member
    65
    44
    US
    If you already have a 220/240v outlet in your garage purchase the plug to match that.
    I already had a 220v outlet for my air compressor so I made sure my charger matched that. Nothing extra to purchase or install.
    Nexus 6P ?
  7. Dudley1030
    Dudley1030 Active Member
    200
    139
    Lawrence, KS
    Clipper Creek has a lot of choices. Just don't change your wall outlet to match a plug. The different outlets are for different amp outputs. I bought a plug-in version from Clipper Creek. I've been very happy with it.
  8. ct89
    ct89 Active Member
    323
    266
    New England
    And as with so many things on amazon these days...Feel free to do some price shopping. You'll find that in this case Clipper Creek will sell the unit directly to you for $16 less. Just visit their store directly.
  9. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
    So True, I was showing diversity in 220 plugs, not best prices, or wisest choices. The examples were chosen because they showed the plug style prominently in the ad.
    i mentioned considering an L14-30 as my daughter want a ceiling plug and it locks. Normally you want that to unplug easily so if you forget to unplug, it comes out at the wall.
  10. jerrymildred
    jerrymildred Senior Member
    11,515
    14,120
    Tampa, FL
    A wise precaution, but I think the Prime is like the PiP in that it won't go if it's plugged in.
    alexcue likes this.
  11. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
    Excellent, I was worrying about damaging her car. (My older brother bought a blue Prime Premium last night, she is thinking about a blue Prime Plus in July. My sister and I each own a grey 2012 Prius V three)
    jerrymildred likes this.
  12. john1701a
    12,755
    5,245
    57
    SAE specs disable the ability to drive when plugged in.
  13. krushmoto
    krushmoto Member
    65
    44
    US
    Can't even start the car with the charging door open.
    Nexus 6P ?
    Dudley1030 likes this.
