Prime Advanced Back-up Bulb Replacement
Discussion in 'Prime Main Forum (2017-2022)' started by bresna, May 14, 2017.
  1. bresna
    bresna Active Member
    193
    144
    Southern Maine
    Someone lightly bumped my right rear corner in a parking lot, in the area where the back-up light is. The clear plastic cracked and the light no longer works. I am not sure I want to spend the hundreds of dollars for a small crack in the cover, but I would like to replace the lightbulb. I've searched high & low on line to no avail.
    Can anyone point me in the right direction? I would like to buy a bulb but I also want to price out a new plastic cover in case the crack causes a leak, which does not appear to be the case right now.
  2. Mendel Leisk
    38,653
    This'll be of interest:
    outch! $700.00 estimate to repair! | PriusChat
    Current car design is totally oblivious to the costs of parking lot bumps, putting fragile sculpture signal lights out on the corners, bumpers that are black-plastic, painted fairings, and stratospheric costs for parts.
    #2 Mendel Leisk, May 14, 2017
    priuscatprimeguy likes this.
  3. 34Hupp
    34Hupp 1934 Hupmobile - Americas 1st Aerodynamic
    62
    100
    Rochester, NY
    Instructions for replacing the Back-Up bulbs start on page 636 of the Owners Manual.....
    #3 34Hupp, May 14, 2017
  4. Tideland Prius
    16,128
    Also note that you should not replace your bulb after driving (if you were using the engine) as the access panel is in vicinity of the exhaust pipe and you don't want to risk accidentally touching the pipe and burning yourself. Best to do it in the morning or before you drive off.
  5. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    I had a shopping cart hit mine. here's the part number I gleaned from my repair 81531-47010 description: lens & body RR T Unit price $387.60
  6. priuscatprimeguy
    2,730
    2,640
    Prius from Dad and Mendel Leisk like this.
  7. huskers
    huskers Senior Member
    2,543
    2,486
    Nebraska
    Man, it seems like a lot of you are hard on these new babies.
  8. priuscatprimeguy
    2,730
    2,640
    yup, the Prime is a "ding magnet":cry:
  9. bresna
    193
    144
    Southern Maine
    It wasn't me! :) I was parked in a lot and a young woman talking on her cell phone backed out of the spot behind me right into my Prime. I didn't even exchange papers because i didn't see the crack. My fault for not checking better. I had no idea that the light was out. Did not expect that at all.
  10. priuscatprimeguy
    2,730
    2,640
    was she good looking?:whistle::rolleyes:
  11. Mendel Leisk
    38,653
    Took a look; those lights are right on the corner:
    Do they actually protrude, not recessed, so say you back into a flat wall, at a certain angle they'll be the first point of contact? Someone should send the design team back to trade school. Looks are great, but c'mon at least some acknowledgement of practicality??
    I've got a vague recollection of some past toyota with bulbous running or signal lights, same issue.
    #11 Mendel Leisk, May 16, 2017
  12. bresna
    193
    144
    Southern Maine
    I don't even think the lens itself got hit or else it might have gotten smashed. I think the girl's Honda Civic bumped the corner of the bumper and the flexing of the plastic around the lens caused the crack.
    But to answer your question, no, this lens does not protrude, but if you do back into a wall, it will still break due to the way they incorporated it into the bumper's plastic. Basically, the made the lenses part of the bumper. My old Priuses (2004 & 2012) did not do this. They had bumpers and they had lights and never the twain shall meet.
  13. Mendel Leisk
    38,653
    Too, these lights have migrated a long way, from just being lights. Now they're statements.
    Sorry, I appreciate I am trolling on this, it's my pet peave. It's not resolving your problem, just grousing.
    WilDavis likes this.
  14. Umana
    Umana New Member
    Los Angeles
    Are the stock bulbs halogen or LEDs?
  15. Mendel Leisk
    38,653
  16. Tideland Prius
    16,128
  17. Umana
    Umana New Member
    Los Angeles
    I am in trouble, in the process of replacing the bulb with LED it fell into the housing of the back taillight and now is inside.
    Looks like I am going to have to remove the taillight/rear bumper to get to it.
    Cant find how to do any of the two.
  18. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    At the least this is replaceable bulb, it seems. With LED lamp like headlight, you don't have that option. You have to change entire assembly for about thousand dollars, I think.
  19. Umana
    Umana New Member
    Los Angeles
    I am going to try one of those swivel magnets and hope I can pull it out that way.
    If not I might need to remove the entire bumper and then remove the tail light to shake it out. I just wasn't able to locate a thread that has the bumper removal guide.
  20. krushmoto
    krushmoto Member
    65
    44
    US
    You don't need to remove the entire bumper to get the assembly out. Just get under the car with a flashlight and remove the clips that hold the splash shield for that side and the 2-3 that hold the wheel well shield and you can pry it out of the way to look at the assembly and undo the fasteners that hold it in place. Did mine at night and took about 10-15 minutes. Looks daunting but take your time. It's pretty simple.
    moto z3 ?
