Prime Advanced HD vs XM products
Discussion in 'Prime Main Forum (2017-2022)' started by schja01, Jun 6, 2018.
  1. schja01
    schja01 One of very few in Chicagoland
    1,744
    1,162
    Chicagoland
    2018 Prius
    First off I despise XM as a company so I don't care about XM Radio.
    but
    The doc on the 2018 Prime confuses me a bit.
    It seems there are several products delivered through either HD Radio or XM.
    Specifically Weather and real time traffic.
    With the Prime Advanced do I have a choice as to which to use? Am I tied to
    XM for those services?
    Thanks,
    J
  2. Bob Comer
    Bob Comer Active Member
    708
    457
    South Carolina low country
    As far as I know traffic is all HD radio. I despise XM too and don't have an account with them. I haven't ever seen any weather related stuff, so maybe that's XM?
  3. schja01
    1,744
    1,162
    Chicagoland
    2018 Prius
    I believe there is a feature to overlay Doppler Radar on the Nav screen. Again I wonder if this is a HD Radio or XM or either.
    Thanks,
    J
  4. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    If I am understanding this correctly hd radio can be on regular radio stations like in my area radio station 89.9 isint hd but 100.3 is hd
  5. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    The radio station decides whether to buy the equipment to broadcast in the HD digital format. One local station has the same programming on their analog 98.1 and digital 98.1 HD1. They have different programming on digital 98.1 HD2 and on digital 98.1 HD3. This is just one example.
    By the way, HD on a radio does not mean high definition or anything else except a specific digital service. The company that started it copyrighted "HD Radio©" for marketing purposes.
  6. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    there's a setting to get the data through either HD or through the web via the entune app (or both)
  7. CharlesH
    2,785
    1,152
    Roseville, CA
    On the first generation PiP, at least in the earlier model years, the traffic info came over Sirius/XM data, and after the initial complimentary subscription expired, you had to set up your own XM data plan (which is a distinct service from the audio radio stations). As I understand it, later models years of the PiP changed to HD radio for traffic info. As mentioned, with the Prime you have the choice of using either HD Radio or Internet service via the Entune app on your smartphone to get traffic info. There is no charge for either of these options.
    FWIW, if you use the Safety Connect service on the Advanced, you are dealing with a subsidiary of Sirius/XM. This is just a matter of corporate ownership of the provider Toyota chose to use; Safety Connect uses a Verizon cell phone built into the Advanced, and has nothing in any way to do with satellite radio service.
    schja01 likes this.
  8. schja01
    1,744
    1,162
    Chicagoland
    2018 Prius
    Exactly what I was looking for. THANKS!
    J
