Prime Cabin Heater Question
Discussion in 'Prime Technical Discussion' started by evpv, Dec 28, 2021.
  1. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    I normally run my Prime with the fan off so the heater and AC are off. I noticed that when running in EV mode with the fan off if the temp is set* to a warm setting (70+ degrees F) I can feel warm air coming from the vents when the car is moving. Where is the heat coming from?
    I understand that in HV mode it could supply passive heat through the radiator or exhaust heat. Maybe in EV mode it supplies passive heat from a cooler for the electric motors or hybrid system?
    *With the fan off you can’t adjust the cabin temp. By “set” I mean: turn the fan on, set the cabin temp to 70+, then turn the fan off. That temp setting stays in memory until you manually change it.
    Salamander_King likes this.
  2. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    I always figured it was from the Flux Capacitor.
    Ovation and dig4dirt like this.
    52,393
    if you turn the temp to low, does the air cool down? what is the outside temp?
    older pri had electric preheaters
  4. ChapmanF
    18,552
    A Prime has an electric heat pump.
  5. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    Interesting observation. I have never checked the vent to feel the warm air coming out, but I do drive my PP with the fan off most of the time. As you noted, when the fan is set to off, HVAC is OFF, and the PP's A/C ratio on the Eco Diary stays 0%. The question is by "feel warm air" what exactly is the air temp in the cabin and outside of the car at the air intake. It may be that the ambient air outside is slightly warmer than the cabin temp?
  6. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    Yes, the vent air temperature goes down when the temp is set on lower settings. I have never noticed that it is colder than the outside temp (no passive AC).
    Outside temp is 55-65F.
  7. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    No, the vent air is noticeably warmer than the ambient cabin or outside temperature. Try it with the temp set to maximum with the fan off. It might happen only while driving because while stationary there is no air movement through the vents.
  8. Salamander_King
    11,024
    8,970
    New England
    I will have to see what I can feel out of the vent. If your outside ambient temp was 55-65F and you are noticing warmer air coming out of the vent, then this passive heat must be substantially warmer than 70F. As I said, I have never checked the vent on my PP while the HVAC fan is set to OFF, but if ~70F or higher temp air is coming out passively, then I am sure I would have noticed it by now. I usually keep my HVAC OFF even when the ambient temp is well below 32F. In fact, I don't usually use heat unless the ambient temp is lower than 20F, but I have never noticed ~70F or higher temp air coming out of the vent in my car.
  9. bisco
    52,393
    is there a way to test if the heat pump is on while the fan is off?
  10. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    Maybe it is just me but the HVAC is considerably loud and noticeable when it is turned on.
    Specifically when stationary and no ambient noise around.
    Even over the whole pedestrian noise maker.
    jerrymildred likes this.
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    I've observed something similar. It's a mystery to me, too because when I stop I don't hear the heat pump running.
  12. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Does the inverter coolant also feed the heater core?
  13. ChapmanF
    18,552
    I've never worked on a Prime, but that would sure be very Prime-specific if it did; nothing like that happens in Gen 1, 2, or 3.
  14. jerrymildred
    11,517
    14,158
    Tampa, FL
    No.
  15. Salamander_King
    11,024
    8,970
    New England
    OK, I run my weekly errand today and drove ~40miles in my PP. I did all 40miles with the HVAC fan set to off position. I was only able to drive on EV mode for the first 25miles or so. During that time, I tried feeling the vent. Absolutely no warm air coming out of the vent. If anything, it felt cooler but I think it is just because of the drift. BTW, the ambient temp was 28F cloudy with some mixed precipitation. When I run out of EV range and switched to HV, even though I did not turn on the HVAC, there was definitely warmer air coming out of the vent.
    #15 Salamander_King, Dec 30, 2021
  16. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    34DD9DED-B67E-45F1-A324-0DF953BB1E1E.jpeg I know, I’ve tried it a few times recently and got no heat using EV. But I’m sure it has happened a few times when leaving my garage in the morning on cool SoCal mornings (we had frost not too long ago). And the air was definitely warm. I’ll continue to test it.
    I also tried it recently using HV and definitely had passive warm air.
  17. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    I think I was using the seat heater with the fan off. And I noticed the vent air was warm. I’ll try that again.
  18. dtsexpert
    dtsexpert Member
    179
    83
    San Francisco
    My observation is similar. Another thing is if you set fan off, air coming from outside, then you pull down the window a bit, you can fell the vent air blow a bit stronger vs when the window close.
  19. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    Agreed, I definitely get more airflow through the vents with the window cracked open a little.
