Prime charger: how much energy during standby?
Discussion in 'Prime Main Forum (2017-2022)' started by stevepea, Nov 3, 2017.
  1. stevepea
    stevepea Senior Member
    535
    581
    Especially for those of you with electronic testing equipment...
    I was wondering how much electricity the Prime's 120V charger uses while in standby mode, until the charging actually starts. I'm assuming it's not very much, but if I have a schedule where I only use the car for a few hours every morning (say 8am-11am) -- and don't want to have to remember to plug it in later in the day or before I go to sleep at night -- if I want to just plug it back in when I return at 11am -- that means it would be plugged in, in "standby" mode for about 15 hours before charging would start... multiply that by 5 or 6 days per week.
    So was just wondering the amount of electricity the included charger actually does use when you plug it in the wall (after the initial clicking and testing, when it reverts to standby mode)....
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,030
    Westminster, Colorado
    I measured about 2-3W.
    stevepea and priuscatprimeguy like this.
  3. Tideland Prius
    16,445
    2-3W... winter or summer?
    Does that include the traction battery warmer function?
  4. Lee Jay
    5,850
    4,030
    Plugged into the wall, not into the car.
    Tideland Prius likes this.
  5. Robin Mitchell
    Robin Mitchell New Member
    San Diego
    I just measured mine (Prime Premium in 70-degree weather) and it shows 0.6 watts with just the cable plugged in and 0.7 watts when the cable is plugged into the car waiting for the charge timer to start.
    fuzzy1 and bisco like this.
  6. bisco
    51,155
    that's a big difference.
  7. Robin Mitchell
    San Diego
    It may be a large percentage difference, but in absolute terms it's still pretty small - the minimum difference between Lee Jay's measurements and mine is 1.4 watts, which is 1/1000 of the power draw when charging the battery.
    For what it's worth, I measured the power consumption using two meters: a Kill A Watt, which has a resolution of one watt and read zero watts, and one of the meters described in this post, which has a 0.1-watt resolution and read 0.6 watts.
    stevepea likes this.
  8. stevepea
    535
    581
    Thanks for the replies and info, folks. Yes, quite a difference between the two readings (though it's a small amount of power regardless). When there's something like 15hrs of standby time before it needs to charge, I may try to remember to plug it in later instead, and see how it goes... though the first time I forget to do so, I'll go back to plugging it in as soon as I get back, long beforehand :)
