Prime EV Range
Discussion in 'Gen 5 Prius Main Forum' started by jonnybonz, Jun 12, 2023.
  1. jonnybonz
    jonnybonz Junior Member
    23
    New Jersey
    Is your calculated EV only range based on your miles per kWh average? For an xse you should get 39miles of range but at full charge it says 32mi. My miles per kWh is at 4.1mi.
  2. Rmay635703
    Rmay635703 Senior Member
    2,590
    1,608
    Somewhere in Wisconsin
    2013 Chevy Volt
    Guess o-meter , reflects recent driving behavior
    Fromvwhat I’ve learned of the Gen V it is really much ch more affect by high speed and weather than the Gen IV
    It’s efficiency drops off a lot past 60mph, unlike the Gen Iv which keeps trucking.
    49,358
    people are getting upwards of 60 iles ev range, depending on driving conditions. the meter will slowly climb as you try to tease out more miles through hypermiling, if yo care to, or it may just go up on its own if it started out low when you got it.
