Prime has new wheels and rims from an FRS!
Discussion in 'Prime Main Forum (2017-2022)' started by Pdxprimeguy, Nov 2, 2020.
  1. Pdxprimeguy
    Pdxprimeguy Member
    Portland
    Used 3mm spacers from amazon. I been waiting a long time to get these rims. Wish I got them sooner! Had to buy the center caps too. Not cheap either.
    620FFF7D-4D2C-4C04-8E03-461FA481C578.jpeg BD7E86B2-1617-40BE-823B-CF1A2B26A812.jpeg
  2. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    Very cool. What size is it?
  3. Pdxprimeguy
    Pdxprimeguy Member
    Portland
    215/45/17. Fits great!
    Salamander_King likes this.
  4. Salamander_King
    10,970
    8,853
    New England
    Let us know how much mpg hit it will have on your regular long drive on the highway. It looks great, but I just can't justify the loss of mpg (or EV range) just for the looks. Plus, wheel costs and more expensive tires. I'm just too frugal.:LOL:
  5. Pdxprimeguy
    Pdxprimeguy Member
    Portland
    They are slightly heavier and I will lose mpg. But worth it for me since I have decided to keep the car longer. Might as well improve the performance and looks!
    Going to hold off for a year or 2 until I get the RAV4 prime.
  6. W204white2010
    W204white2010 Junior Member
    So Cal
    2018 Prius Prime
    I sincerely apologize for bringing up such an old thread.
    I recently bought a set of BRZ factory wheels that looks exactly like OP’s.
    My question is, are the 3mm spacers the only parts I need to get these correctly installed?
    Thanks in advance.
  7. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    You're going to need a different set of lugnuts as well.
  8. 00PowderSpecial
    00PowderSpecial Junior Member
    Newfoundland
    2022 Prius Prime
    Technology
    Those look great. I have a set of new brz wheels lined up. Why do we need a 3mm spacers? I figured some splined cone lug nuts would be it
  9. xliderider
    7,869
    3,116
    Honolulu, HI
    Regarding the need for spacers, Gen 3 Prius hatchbacks had clearance issues on the rear with the brake caliper holders.
  10. W204white2010
    So Cal
    2018 Prius Prime
    Thank you so much for the quick responses.
    I looked up the BRZ wheels and it says the hub bore is 56.1mm, while the Prius' hub bore is 54.1.
    Would you be so kind to point me in the right direction as to where I can obtain the correct spacers and lug bolts all at once?
    Thanks in advance boss!
  11. xliderider
    7,869
    3,116
    Honolulu, HI
    #11 xliderider, Jun 6, 2022
  12. W204white2010
    So Cal
    2018 Prius Prime
    Wow thank you so much!
  13. W204white2010
    So Cal
    2018 Prius Prime
    So sorry, one last question, do I just need longer lug bolts for the rears or would I need to change them all together due to conical/ball seats on the lug bolts?
  14. xliderider
    7,869
    3,116
    Honolulu, HI
    You can get by with the original wheel studs, just don't over torque the lugnuts.
    Yes, you will need a set of lugnuts with conical or acorn type seating area.
  15. W204white2010
    So Cal
    2018 Prius Prime
    Thank you so much for always responding so fast and all the information!
