Prime is longer than a standard Prius.
Discussion in 'Prime Main Forum (2017-2022)' started by padroo, Jan 30, 2018.
  1. padroo
    padroo Senior Member
    2,763
    2,251
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,030
    Westminster, Colorado
    A little more overhang. Same wheelbase.
  3. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    662
    263
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Maybe a design consideration for the extra batteries?
  4. padroo
    2,763
    2,251
  5. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    ...also thought the rear hatch door of carbon fiber construction was wider
  6. padroo
    2,763
    2,251
    It very well could be wider. An inch or two doesn't sound like much but it is a really big deal in cars.
  7. Tideland Prius
    16,445
    Is it? Wouldn't that require a change in the rear body panels? (or maybe the taillights are thinner in design than that of the Z-shaped Gen 4 so that's where the extra space went...)
    But yes, the Prime is longer to accommodate the battery and for the design of the car.
    While I appreciate the compact dimensions of the Gen 2 and 3 designs, they were definitely limited in their design cues and required a sharp nose to accommodate the length of the car. On the Prime and Gen 4, they can smooth out the slope a touch.
    The Prime is a total of 6" longer than the Gen 3 or about the length of a Prius v. Some of that is to accommodate the style that the designer wanted on the Prime.
    padroo likes this.
  8. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    Size matters.
    pilotgrrl, Dudley1030 and padroo like this.
  9. DavidA
    2,342
    1,818
    Chicago western burbs
    There is also the consideration of additional crash protection crumple zone in the rear of the Prime due to the increased battery volume/energy vs. the Gen4.
    padroo likes this.
  10. wjtracy
    11,361
    3,606
    Northern VA (NoVA)
    I forget but I sort of convinced myself re: Cargo space that on the inside there is not much more cargo length in the hatch of the Prime
  11. DavidA
    2,342
    1,818
    ^ The thickness of the bottom of the hatch erases any total length that is gained. Also, the top glass indentation reduces the length higher up.
  12. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Open the back hatch, push it up and look at the bottom.
    Thar sucker is thick. I guess that carbon fiber needs the thickness ?
  13. bisco
    51,155
    good things come in small packages.
  14. DavidA
    2,342
    1,818
    Should I tell you that it isn't even carbon fiber?
  15. Tideland Prius
    16,445
    Yeah but supposedly the width is there to fit a set of golf clubs (I think with the golf bag).
    Well the bumper is thick too so I think it goes hand-in-hand. Can't tell if it's thick because of the CF or if it's because of the design of the rear end.
    Carbon fibre reinforced plastic.... yes..
  16. DavidA
    2,342
    1,818
    It is some sort of fiber. The carbon content % is suspect but probable. The carbon fiber look is a plastic look-alike overlay.
    There is a close-up photo of the not-carbon-fiber overlay at 10:25 in with this episode of What Drives Us. A quick look from a distance and you might say it is classic CF. An actual close inspection shows that it isn't. Tap the dark portion of the hatch from the inside with your knuckles or fingernails and compare against another large object that you know is real (and expensive) CF with built up layers. Not the same sound or feeling at all. I wonder how much weight they are really saving? The marketing department is likely spinning up a feature and benefit there. I would call the hatch more plastic-something than fiber-something.
    #16 DavidA, Jan 31, 2018
  17. Tideland Prius
    16,445
    Again, the actual name of the material used in the Prime is "CFRP" - carbon fibre reinforced plastic. Yes it's not the layers upon layer of carbon fibre material woven into a cloth like the LFA or McLarens. It's similar to the i3.
    It saves 8 pounds over the aluminium hatch of equal design.
  18. Rmay635703
    Rmay635703 Senior Member
    2,647
    1,670
    Somewhere in Wisconsin
    2013 Chevy Volt
    And that is why the Prime should have just been installed to the Prius v
  19. Tideland Prius
    16,445
    Can't - weight limits for the chassis.
    It's one or the other (the v and Prime weigh almost the same with the Prime about 50-70kg heavier). Add the "v" bodystyle and you won't be able to carry much cargo before exceeding the cargo carrying capacity or resulting in poor vehicle performance.
    Basically, the v needs to be on the bigger platform for it to happen. (assuming Toyota has a TNGA platform between the Corolla and Camry size)
  20. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Below are a couple of graphics that I created last year when this topic came up which shows the Prime and the liftback side by side.
    Comparing the specs on the two vehicles the length difference is 1 inch in front and 3.2 inches in rear, 4.2 inches total.
    Height/Width/Length
    Prime 57.9 69.3 182.9
    Liftback 58.1 69.3 178.7
    Overhang Front/Rear
    Prime 38.4 38.2
    Liftback 37.4 35.0
    Ground clearance
    Prime 4.8
    Liftback 5.1
    Here's a side-by-side that I made from the photos on the Toyota website. The Blue Magnetism is the Prime
    Here is a superposition. The little bit of Blue Magnetism that you see sticking out in the front and rear is the Prime.
    Tideland Prius likes this.
