Prime Premium Not Charging
Discussion in 'Prime Plug-in Charging' started by Ian Hertz, Feb 4, 2020.
  1. Ian Hertz
    Ian Hertz Junior Member
    2018 Prius Prime
    Oem plug. 120 socket. Happens random after driving 20 minutes but more frequently lately. Don't use schedule. '18 model.
  2. jerrymildred
    jerrymildred Senior Member
    11,516
    14,120
    Tampa, FL
    More info, please.
    When you plug it in, does the green LED at the port come on and stay on? That's what it does if it's starting to charge. If it blinks a few times and then goes out, that means it is waiting for the next scheduled charging event.
    Starting on page 170 in my manual is a lengthy section titled, "When normal charging cannot be carried out."
    Since it happens right after driving, it may be that the battery is too warm and it'll charge once it cools down. However, the only time that it's prudent to charge right after you park is if you're leaving again soon. Not good for the battery to let it set long term all charged up.
    Salamander_King likes this.
  3. Salamander_King
    Salamander_King Senior Member
    10,975
    8,870
    New England
    jerrymildred likes this.
  4. Ian Hertz
    2018 Prius Prime
    Hello Jerry,
    The LED doesn't come on. Orange light on plug (indicating power) is on. Never had green flash as I don't use scheduling. The temps are in 50s and my driving is ACC set at 65. I've driven in near 100 degrees at 75mph and didn't have this problem. Why would battery be so hot lately.
    I normally leave it plugged in for 8+ hours. During recent non-charge event, I left it plugged in for 1.5hrs and when I went to car, I had to unplug and replug for it to start charging. I don't have luxury of parking, walking away and coming right back to charge. Once I walk away, it's usually 8 hrs before I can get back to it.
    Any other suggestions?
  5. jerrymildred
    11,516
    14,120
    Tampa, FL
    Well, it occurs to me that there might be a problem with the EVSE cable. But if you can come back in an hour or so and make it work just by unplugging & replugging, that seems to indicate some condition with the car.
    Process of elimination: if it was the scheduler, the green light in the port would blink at you. If it was the cable, you should get a fault light on it. If it was the outlet, you'd get no power light. The only thing I can think of that fits, is that the battery is too warm when you plug it in, but when you come back 1.5 hours later, it is cooled down.
    Using the scheduler would alleviate this. It will also help your battery to last longer. Try using the scheduler for a while and see what happens. Set it for departure time and time it to stop about an hour sooner than you leave to be sure it finishes. My guess is that you'll come back to a fully charged car every time. If it happens again, driving home at 50+ mpg isn't the worst thing that can happen.
  6. Ian Hertz
    2018 Prius Prime
    I wish I updated sooner but problem was with cable, which was replaced under warranty.
  7. bisco
    49,523
    thanks!
