Prime up to mischief? Loud fan noise in garage
Discussion in 'Prime Main Forum (2017-Current)' started by Michael Nielsen, Apr 21, 2017.
  1. Michael Nielsen
    67
    87
    Dover, DE
    So I didn't drive the Prime yesterday and it was fully charged from the day before so it was not plugged in. Ambient air temperature around 60f this afternoon. I get by the door to the garage and I hear a racket. I open the door and the noise is coming from the front of my Prime. It sounds like a fan running at top speed. I go around to the driver's side and get in to the car. I am guessing that by some weird circumstance, I have left the car running for two days. However, the dash is not lit up. I start the car up. The usual boot up stuff happens. The fan noise stops. I check the battery level meter and it shows full charge, 33 miles of range. I turn the car off. No fan noise. Any ideas?
    Mike
    #1 Michael Nielsen, Apr 21, 2017
  2. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,297
    3,502
    Anaheim, CA
    It sounds like you may have (unintentionally?) triggered the remote air conditioning or heating command from your key fob. When I activated my remote cooling on my 2012 PIP, the PIP
    made that fan (compressor?) noise. Also, doesn't the Prime (depending on model) have the ability to schedule cooling? Good luck!
    priuscatprimeguy and iplug like this.
  3. Michael Nielsen
    67
    87
    Dover, DE
    Ah Ha!!! And as Homer Simpson says, DOH! Thanks.
    HPrimeAdvanced likes this.
Loading...
