Prime with no jack?
Discussion in 'Prime Main Forum (2017-2022)' started by Nate_F, Aug 23, 2017.
Tags:
  1. Nate_F
    Nate_F Junior Member
    30
    Idaho
    I purchased a Prime Premium about a month ago. I just decided to look around in the back of the car and I see tire and jack accessories but no actual jack.
    It looks like the jack's part number should be 09111-47050. Can someone confirm they had a jack come with their vehicle?
  2. alexcue
    alexcue Active Member
    346
    311
    So Cal
    under the rear seat? small compartment. drivers side
  3. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    There's a secret hiding place under the rear seat on the driver's side.
    HPrimeAdvanced likes this.
  4. Nate_F
    30
    Idaho
    Wow. I would have never found that. I'm too tall to even see it. Probably in the manual but I assumed that big open space in the back nearest the hatch is where it should have been.
  5. bisco
    52,409
    yes, o/m.
  6. litesong
    litesong Active Member
    371
    122
    Everett, WA
    With my bad back, any jacking could lay me low, easily. Fortunately, at a garage sale, i found a lighter weight, but fairly heavy duty ELECTRIC car jack that I love. It helped me to switch 8 total wheel/tires from one car to another & vice-versa, by only needing one manual jack, & that only to hold the frame up. All jacking up & down was by use of the electric jack. I did a lot of wheel unbolting & bolting & was sure my back was getting ready to quit, but the electric jack really saved me. Oh, yeah.The garage sale electric jack cost $10.
    benagi and bisco like this.
  7. bisco
    52,409
    get a bigger breaker bar :)
  8. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    forget the breaker bar, get a portable impact wrench (medium torque should do it). it'll take those lugs off in seconds with very little effort, and as a bonus you can use them to take off everything else as well (caliper bolts, as well for very quick pad changes). I used to carry a large breaker bar as well until I got one and now I just carry an impact wrench in my car with set of flip-sockets. And bonus you can get one cheap with all the sales going on right now.
  9. Mendel Leisk
    41,934
    The Toyota scissor jack style is has a poor design linkage at the torsion bar connection. It's a single-eye casting, like this:
    The torsion bar hooks into that eye; then you crank it. Being single-eye, it tends to jump around a lot, with every revolution. You can get where you want to go, but you curse it with every turn. It also seems like very soft metal, it starts spalling off right away.
    Honda by comparison uses a U-shaped bent plate, with double-eye, and that simple change keeps the torsion bar hook much more stable as you turn it:
    Elektroingenieur likes this.
  10. bwilson4web
    16,382
    Had a lug nut welded to jack and tossed the ‘crank’ wire.
    benagi and Mendel Leisk like this.
