Prius 12v Battery - Manufacturer Date
Discussion in 'Gen 2 Prius Main Forum' started by tampaite, Apr 28, 2025.
  1. tampaite
    tampaite Member
    236
    42
    FL
    Got an oil change done and one of the recommendation from the Toyota dealership was to replace the 12v battery as it failed load test.
    came home and ran the basic test and result below:
    • Shows 12.2 on start-up
    • Shows 11.3 when headlight is turn ON
    • Shows 14.2 when engine kicks-in
    Is it time for the 12v battery to be replaced?
    Also, need your help on two things:
    • trying to figure out the battery date(pls see photo) - Says 01 11 18W
    • If it's 2018 - then likely got like 7 yrs from the battery?
    • There is a wire that's just hanging out - does this need to be plugged in? I tried to plug into the white plastic slot but it maybe broken.
    Appreciate your help!
  2. Mendel Leisk
    40,587
    What is “basic test”? Some self-test in the car’s dash?
    Do you have a digital multimeter? Try testing voltage with the car off, first thing in morning.
    tampaite likes this.
  3. tampaite
    tampaite Member
    236
    42
    FL
    Correct - using the car dash ( press the power once - press and hold INFO and turn the headlights 3x to get into the diagnostic menu)
    I can check with multimeter and post it in the morning.
  4. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    Before checking any voltage you need to do a full charge which will take a minimum of 18 to 20 hours if the battery is near fully discharged. Then check the voltage two hours after removing the charger. You want to see 12.8 to 13.2 V. Then put a load on the battery and see what it voltage it drops to and whether it can hold that voltage for 10 to 15 minutes. If the voltage drops and keeps going past 10 V your battery needs replacing.
  5. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    Third planet from the Sun
    Yes, the battery is from 2018. There is a temperature sensor on top. The white slot is used to attach the sensor connector.
  6. Mendel Leisk
    40,587
    Voltage checks are better than nothing. Still, if you want a better assessment there's a fairly recent generation of electronic load testers on the market, with typical pro-sumer levels costing $50~100 USD. I'm using a venerable Solar BA5, current iteration being BA9. Autel and Topdon are also popular.
    Typically, you enter a few stats about your battery, activate the test, it shows the as-tested CCA, and might give a verdict on the battery's condition as well. With my BA5 the verdicts are "good", "good but needs charging", and "fail".
    The dealership likely tested your old battery with a tester of this ilk, and could do the same for your new battery, to either allay your concerns or check whether or not they've installed a dud.
  7. pasadena_commut
    pasadena_commut Senior Member
    2,282
    680
    Southern California
    Caveat - only use this sort of tester right on the battery. Testing at the jump point is more convenient but gives incorrect results.
    Another option is to take the battery out of the car and bring it to an auto parts store and they can test it. Best if it is fully charged before doing this, otherwise they can usually charge it on site, but that will take a while. The testers I have observed in the parts stores are different than the little ones discussed here. These are of substantial size and weight, although it can still be held in one hand, and can put more of a sustained load on the battery. It isn't like one of the old fashioned battery testers that is big and heavy and wheeled around though. These part store testers appear to have active (fan) cooling of the resistive element, so it can apply a load for many seconds, but not for minutes.
    Example of a little electronic one:
    12V Digital Battery and System Tester
    Example of a parts store tester:
    https://www.autometer.com/bva-260-professional-grade-intelligent-hand-held-electrical-system-analyzer-for-6v-12-applications.html
    (you can see what they are using at some points in the video)
    Example of a heavy duty load tester:
    Associated Equipment 500 Amp Carbon Pile Load and System Tester, Model 6042 | Remy Battery
  8. tampaite
    tampaite Member
    236
    42
    FL
    After leaving the car overnight for about 10 hrs, the multimeter shows 12.39v.
    Tells me the battery is healthy - I got 7 yrs maybe another year or two?
    Local Toyota dealer has the 12v battery( Toyota TrueStart Battery, Group S46B24R - 84 Month Warranty - Part Number 00544-21171-325) on sale for like $173 + Tax and available for local pickup
    Should I replace it now by myself or hold off ?
  9. Mendel Leisk
    40,587
    Considering the age (7 years), and the dealership saying it failed load test, I’d replace it before next winter. That’s a good deal for the battery, and DIY is straightforward.
  10. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    The voltage is normal. This means that the leakage on the switched off car is insignificant.
    But there is another important parameter - the internal resistance of the battery. The lower it is, the better the condition of the battery.
  11. tampaite
    tampaite Member
    236
    42
    FL
    Just for the heck, took the car to AutoZone after work and they load tested and it showed at 74% health. Not sure who to believe.
  12. Mendel Leisk
    40,587
    Not sure what “health” would be. With an electronic load tester, I figure if CCA has dropped lower than spec, it’s time. Your case I’d leave till the fall. You can see for yourself with one of the Solar, Autel or Topdon testers.
  13. Aegean
    Aegean Active Member
    454
    203
    Alexandria VA
    My 12v battery was installed in 2014. Health at 60% at 11 years but since only runs electronics I will not change it for a couple more years. However if you use the Prius for travel, better change it proactively at 10-12 years to be on the safe side to not leave you stranded far away from home.
  14. BiomedO1
    BiomedO1 Senior Member
    2,821
    1,500
    SacTown, Ca
    A DVM reading only tells you what the 'resting voltage' of the battery is. A load test is a more accurate assessment of the battery. That's why you turn-on the headlamps and take another reading - poor man's load test.
    Hope this helps....
    FWIW; there are a lot of different load testers out there; so YMMV
  15. pasadena_commut
    2,282
    680
    Southern California
    Health tests are some black magic formula which we don't know. The internal resistance and capacity tests are on more solid ground.
    BiomedO1 likes this.
