Prius 2 2006 problem batterie cell
Discussion in 'Gen 2 Prius Technical Discussion' started by jelt, Aug 28, 2024 at 11:25 AM.
  1. jelt
    jelt Junior Member
    France
    Hi
    I have a question
    Look my picture Dr Prius
    I have bad cell when I left in holidays with car
    I ran 500 kms with bad error dead on Prius
    I run and I deleted the error
    I use climatisation and all electric cars to not let battery max level
    Then I arrive
    No explose battery
    Then I open the battery and change 3 first bank cell then 6 cells
    And look the dr Prius diag
    error no happen
    But it’s say bank one is not good
  2. Tombukt2
    Tombukt2 Senior Member
    9,638
    1,686
    Durham NC
    Well then you have to do it again and deal with the block that the app is telling you is suspect You need to find out why that is with your test meter so that means you've got to open the cover and know the drill
