Prius 2 base JBL radio to OE NAV JBL swap?
Discussion in 'Gen 3 Prius Audio and Electronics' started by N2DEEP, Jul 24, 2020.
  1. N2DEEP
    N2DEEP Junior Member
    Iowa
    Searched and searched but did not find a definitive answer....
    I have a 2011 with the basic radio with JBL amp, is either one of the 10-11 touchscreen radios with JBL able to work (other than back up camera/nav function)? OR is my only option aftermarket and bypass the OE amp?
    Basically would like to use it for the touchscreen.
    Thanks in advance
  2. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    It’s quite usual to replace the non screen head unit with one with navigation, so shouldn’t be an issue. I would check ToyoDIY if anything else is needed.
  3. Attila Fekete
    164
    59
    Budapest, Hungary
    I have attached an Excel file. In that you may find useful information on the head unit connectors.
    It's not complete so if anybody has info to add, it's welcome.
    SFO likes this.
  4. N2DEEP
    Iowa
    Thank you sir! Much appreciated!
