Prius 2002 crunking sound when accelerating or braking
Discussion in 'Newbie Forum' started by Mbogo Patrick, Oct 14, 2018.
  1. Mbogo Patrick
    Mbogo Patrick Junior Member
    Kenya
    2002 Prius
    I hv a toyota prius 2002 which hv been working fine bt has developed a mechanical problem which the mechanic is unable to fix yet. The car is producing a crunking sound after starting n hard accelerating n then of late when breaking also or when going uphill its like producing that sound continuously unless u light press the gas which means u will be very slow. It's like there are some gears or something that is "jumping" or has won out when the car requires power to accelerate hence the sound
    The mechanic hv suggested replacing the gearbox.
    I also hv done some research abt the issue n I think maybe it's the motor generator 2 inside the gearbox that might be hvg an issue.. Kindly advice if you can assist in resolving this issue
    Thanks in advance
    49,511
    possible. did he thoroughly inspect the cv joints and axles?
    Skibob and PriusCamper like this.
  3. PriusCamper
    PriusCamper Senior Member
    11,106
    4,520
    Pacific Northwest, USA
    Yea... What bisco says about focusing on axles and CV joints... Once that's eliminated and you're sure you have no error codes or problems with your engine, your battery or your inverter generating normal amount of power, it's time to do a full diagnosis of transmission with a mechanic who's experienced with Hybrid transmissions.
    Skibob likes this.
  4. Mbogo Patrick
    Kenya
    2002 Prius
    Yes I already have changed the cv joints and the left side front shaft bt still the crunking sound is still there
    He did a full diagnosis and there was no error code
    #4 Mbogo Patrick, Oct 15, 2018
  5. bisco
    49,511
    i would think the tranny would throw an error code, but not sure. i would be reluctant to replace the gearbox without being sure. how much would it cost?
    car isn't worth much here, how about there?
  6. bisco
    49,511
    anyway to post a recording of the sound?
  7. PriusCamper
    11,106
    4,520
    I'd be happy to post a recording of the sound... What would you like me to make it sound like? :)
  8. Mbogo Patrick
    Kenya
    2002 Prius
    Will record the sound and post here
  9. Mbogo Patrick
    Kenya
    2002 Prius
    Will do another scan with a different person n post if there will be any error code. Of late it has turned on the master warning light though
  10. bisco
    49,511
    there have to be codes with a light, anyone have tech stream?
