Prius 2005. Won't start. No DTC code
Discussion in 'Gen 2 Prius Main Forum' started by try4141, Jan 26, 2011.
  1. try4141
    try4141 Junior Member
    houston
    2001 Prius
    I
    Hi all,
    My Prius 2005 with 105K won't start. When I hit the START/STOP button while pressing the Brake pedal very hard, the READY lighthe blinks a few times then disapears. I used a Acton OBD II to find the codes, but NO DTC was logged. What could be the problem? I am thinking about towing it to the dealer next week.
    Thanks
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Check your 12V battery, making sure it is fully charged and has a good ground connection.
  3. try4141
    houston
    2001 Prius
    I
    Took the car to dealer and found out that the Inverter/Converter was bad. Bought an used one from a local junkyard for $400.00 . Works like a champ now. Thanks
  4. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    How did the dealer figure out that the inverter was bad? Good job on the DIY salvage replacement!
  5. wirelessjava
    wirelessjava Member
    103
    Union City, CA
    I had an intermitted start and reset no codes no start but 15 min later the car starts?
  6. bisco
    49,397
    the dealer code reader is able to read the inverter code, wheras, his acton scanner is useless on a prius
    wirelessjava likes this.
