Prius 2006 dilemma with low miles
Discussion in 'Gen 2 Prius Main Forum' started by Peterhans, Jan 16, 2022.
  1. Peterhans
    Peterhans Junior Member
    103
    Germany
    The 2006 Prius has 69k miles and in good condition. OBD2 test shows weak block 9. Ordered two tested models from the UK and arriving soon. Preparing for replacement and reference videos and taking notes. My hope is that this is not a continuous weekend project. I am planning on keeping the car for two years and then upgrading. I have also noticed from some assembly procedures that the modules should be torqued to 48 inch-pounds. What do you think? I also realized that with the virus keeps driving down.
    nancytheprius likes this.
  2. Peterhans
    103
    Germany
    I am also taking notes and photos. Besides the dilemma, how far or miles or length can one drive? I did place a restriction to driving on the autobahn.
  3. alftoy
    alftoy Senior Member
    1,132
    514
    Saskatchewan, Canada
    What is the dilemma? The weak block, having to replace it, or may be a continuous project.
    Pristine Prius with 69K miles and having the skills to recondition and rebuild the HV battery shouldn't be a dilemma. I would look forward to the project. Depends on your mechanical skills.
    How far miles to drive and driving restriction, shouldn't be a problem if no check engine lights or red triangle.
    #3 alftoy, Jan 16, 2022
    Peterhans likes this.
  4. Another
    Another Senior Member
    1,818
    515
    Naples, Florida
    You’d be crazy to sell it for this reason.
    srellim234 and Peterhans like this.
  5. bisco
    51,154
    with a gem like that, i would put in a new battery. no worries as long as you keep it, and when you're ready to sell, it will be worth more.
  6. Peterhans
    103
    Germany
    My thought is a continuous project because of the age of battery module. Just making sure on the right path.
  7. ChapmanF
    17,345
    And if your later question was for opinions about tightening things to the specified 48 inch-pound torque, yes, that's important.
    48 inch pounds is quite a low torque (by automotive wrenching standards) and requires using a torque wrench with a suitably low range so that 48 inch pounds will not fall in its inaccurate lower region. Overdoing it can risk direct module damage by breaking the studs, and underdoing it can risk damage through localized heating.
  8. Peterhans
    103
    Germany
    Thanks. I noticed the torque setting and the range is similar for bicycle. Found source on Amazon.
  9. mr_guy_mann
    mr_guy_mann Senior Member
    3,966
    1,914
    NJ-USA
    It is certainly possible that this could turn into a "continuous project". The problem is that the modules that you purchase are unlikely to be in the same condition (effective capacity and state of charge) as the existing modules in the pack. So the voltages may not be very close to each other under all charge and discharge conditions. If the voltage differential between any of the blocks (1 block = 2 modules in series) becomes too large then the battery ecu will set more codes.
    Based on the various threads in the forums, I would guess that "just replacing the bad module(s)" has around 10% chance of being successful.
    What seems to work better is to perform slow discharge and charge cycles beyond the normal upper and lower voltage limits. Some use a grid charger to cycle all the modules at one time, while others use (multiple) hobby RC chargers to do individual modules. Both take more time and knowledge to perform well vs. just replacing the entire pack.
    Use the search function to find days of reading about refurbishing the battery.
  10. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    After replace the failing module(s), you should recondition/balance the HV battery by using a "grid charger".
    Though I've traveled on the Autobahn in a tiny Polo at 220+ kph, I wouldn't recommend exceeding 120 kph in a Prius with an older battery.
  11. Peterhans
    103
    Germany
    I hope that it is better than 10%
  12. mr_guy_mann
    3,966
    1,914
    NJ-USA
    Well, search and read posts. Lots of people replace a module or two (no other balancing or cycling), maybe it goes a week or two or maybe it doesn't work at all, and the ecu sets a P30xx- "block #xx becomes weak". So they replace THOSE modules. And repeat as needed.
    There's a name for it here. Whack a mole.
    I think I have seen A single thread where someone got a year or two with no problems. Maybe a couple others where they went 6 months to a year.
    kenoarto and Peterhans like this.
  13. Peterhans
    103
    Germany
    On a post after replacing a cell, the person drove for a short time to clear all the codes. I plan on cleaning the buss bars for better connections and that can not hurt.
  14. nancytheprius
    nancytheprius Active Member
    357
    153
    iowa
    let us know your results!
  15. Peterhans
    103
    Germany
    The 2006 Prius is 16 years old with 69k miles. Normal battery usage should be over 150k miles. So, there is much life in the Prius. The value of a Prius with a weak module is not much. Dealer claims that the car is worth about the same price as a battery change. This is an expensive repair. Got the torque wrench and parts coming soon. Neighbor has bench for repair. A suggestion is to change out the entire pack instead of the cell. Trying out first the module approach.
  16. bisco
    51,154
    are you experiencing the high prices of used cars like we are?
    i would never take a dealers word for anything
  17. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    I’ve been down this exact same road 5 years ago with an 06 with only 42k miles. (See link in signature below).
    The repair method (wak-a-mole) fixes the weakest link in an old chain of modules..... till the next bad link breaks. To continue the analogy, a 17 year old battery is a very rusty chain.
    Replacing the battery with a new one is the best in terms of both performance and reliability and will only increase the value of the vehicle. Other than a higher initial cost, there really is no other downside.
  18. drone13
    drone13 Active Member
    140
    115
    SoCal
    A low mileage 06 Prius is a rare find and worth fixing and keeping. It's worth throwing a new HV battery in it and when you go to sell it having a new battery with a receipt will make it worth more on the already high used market. Just do diagnostics on all the major systems and if it checks out OK, spend the scratch on a new HV pack (not refurb) and you will have a very reliable vehicle for a long time with good resale value when you're done with it.
    Unless you are willing to spend a lot of time trying to revive an old pack, and doing that on a regular basis going forward, you should really consider a new HV pack.
  19. alftoy
    1,132
    514
    Could also build a cheap grid charger.
    Can I borrow your battery charger/balancer/reconditioner? | Page 7 | PriusChat
    DIY Grid Reconditioning Charger | PriusChat
  20. Peterhans
    103
    Germany
    I have not looked but would not be surprised. Still learning more such as health of the battery.
