Prius 2006 Hazy Headlights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Friendlyx, Dec 17, 2021.
  1. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    Hey everyone! I'm wondering if anyone can help me, over the past few years I've used so many products to clean up the headlights. Some work and clear them for a few months and some don't work at all. I'm wondering what has worked with you guys? Also, anyway to get the bulbs to be better? I have some bulbs but they are horrible at night to see compared to my Prius 2015.
    Thanks everyone!
  2. Another
    Another Senior Member
    1,818
    515
    Naples, Florida
    You need to seal the lens after cleaning with a UV protectant.
    There are many
    Here is one
  3. alftoy
    alftoy Senior Member
    1,132
    514
    Saskatchewan, Canada
    #3 alftoy, Dec 18, 2021
  4. pasadena_commut
    pasadena_commut Senior Member
    2,277
    678
    Southern California
    Mine are not too bad and for the time being I am just waxing them. That holds up for a few months, then they get dirty and I wash them off with a bit of detergent to strip the wax and reapply. Advantage: cheap and not too time consuming. Disadvantage: not a permanent fix. On previous vehicles I have been down the road with sanding, coating, etc., etc. and none of those fixes hold up for more than a couple of years in SoCal - too much heat, dust, and UV. When my current ones get beyond the point where waxing is good enough I think I will just replace them with a pair of TYC's from RockAuto, which are only $140 (plus tax and shipping) for the pair.
  5. Mendel Leisk
    40,575
    Maybe with hazy headlights all bets are off, but anyway, IIRC with any car we've ever had, there's a caution to not use wax on headlights. This is from page 343 of 2nd gen Owner's Manual:
    I'll resist getting into my rant about how things have not improved, since the demise of sealed-beam glass headlights. Ah woops...
  6. Another
    1,818
    515
    Naples, Florida
    Instead of wax, just apply the Blue Magic spray once every three months. Takes five minutes. One bottle lasts years.
  7. alftoy
    1,132
    514
    2k clearcoat apply once. lasts years. For the same price. Every vehicle has 2k clearcoat protecting paint. Should be OK for poly carbonate.
  8. Another
    1,818
    515
    Naples, Florida
    yep, that will work too
    Advance Auto Parts - Down for Maintenance
    $6 or less
  9. pasadena_commut
    2,277
    678
    Southern California
    In my experience that stuff attracts dirt even worse than the wax does. It is very dusty and dry in SoCal, lots of little particles in the air. If a surface is even slightly tacky (which the Blue Magic is) that builds up a thin coat of, well, mud, very quickly. Perhaps that isn't a problem elsewhere.
    I believe the warning against waxing the headlights is because they are afraid some grit will get mixed in and then when the wax is polished it will scratch the headlight plastic. Perhaps that might actually be a problem on new and pristine plastic, but on old hazy plastic it seems like a minor worry.
  10. Another
    1,818
    515
    Naples, Florida
    It appears we’ve given the OP at least three things to try. Hopefully he’ll report back on one or more of them.
    nancytheprius likes this.
