Prius 2007 2gen hybrid help
Discussion in 'Gen 2 Prius Main Forum' started by Patek111, May 15, 2024.
  1. Patek111
    Patek111 New Member
    CT
    I have Prius 2007 2 gen hybrid I have just changed the dead cell in the battery and changed coolant storage pump and now I have a P0420 code how do I fix that? And sometimes the abs sign comes and then goes away. Thank guys for taking the time to read this.
  2. Tombukt2
    Tombukt2 Senior Member
    9,218
    1,618
    Durham NC
    P0420 is your catalyst below threshold meaning your catalytic converter is worn out or it doesn't meet the parameters for the computer to call it good I'm in a state where I don't have to pass emissions so this doesn't matter but the many and the rest of the country it matters very much generally you're going to be buying a Toyota converter putting it on the car and probably let the Toyota dealer handle it so they can deal with the paperwork when it doesn't put the light off or something not so great happens.
    You can try a spacer on the downstream O2 sensor and see if that works but you want to get something not a spark plug fowler You want a real spacer it'd be made out of stainless or gold medal or something pretty heavy duty they're about 18 bucks
    #2 Tombukt2, May 16, 2024
  3. Patek111
    Patek111 New Member
    CT
    Also I have the red ring of death the red triangle sign with exclamation point, would this problem be fixed if I replace the oxygen sensor and catalytic converter?
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,483
    1,585
    NJ-USA
    No, the P0420 should only trigger the "check engine" light. The red triangle (master warning light) is usually the result of faults in the hybrid control system. You need a capable scantool to check all systems for fault codes.
    (It could be related to your previous repair of the HV battery)
    https://priuschat.com/index.php?posts/3290690
    Brian1954 likes this.
